kharland17
kharland17
Kyle
San Carlos, CA
Jeep Wrangler JL Rubicon
Also going off that hood bezel you do need 2 screws to hold the bezel in place. Doesn't come with the bezel, ran to the local hardware store to pick those up. I'll get some shots with the liner off the hood.
HoosierUte
Indiana
2018 Wrangler Sahara, 2018 Jeep Renegade
Intellectual Property
Did everything come painted?
Kilroy1941
Ny
Jeep gladiator 2020
Hey Everyone,
So I've had my fair share of jeeps from 2 doors to 4. When the pandemic hit I had to Switch over to a truck to haul around more equipment (I'm a fitness trainer) so i went to a JT Mojave. 4 months later I found myself hating the JT, it just wasn't my wrangler. I ended up driving down to Rydell Jeep in Southern California and picking up my 2 Door Rubicon while trading in my JT for basically what I paid for. Shout out to them. Anyways I wanted the Mojave hood for the 2 door and searched the Forum. Here is the true parts breakdown if you want to make the conversion.
Parts / Part #
Hood 68338381AC
Bezel 68398765AB
L/Seal 68405001AB
R/Seal 68405000AB
Hood Liner 68346961AA
Push Pins x 12 6504135
F/Seal 68295588AB
Side Seals x2 68272214AA
Cowl Panel 6NT06TZZAA
Left Cowl 6NT09TZZAA
Right Cowl 6NT08TZZAA
Lower cowl 68291874AC
Hood hinges x 2 68302114AB
SCREW. Cross Recessed Head. x 4 06512790AA
Cost was about $1018 total
Now couple things the be aware of, Everything mounts up but since the hood is a little bit taller the sensor doesn't turn off. Easy fix just added a couple plastic push pins that fit the hole and it turned off.
*The last two part numbers (hood Hinge and Bolts) are a must. the Rubicon Hinges are just barely off enough to not seat the hinges. The bolts that go to the upper cowl when you make the swap are much longer than the Rubicon hood so those have to be swapped out.
**the spring for the hood fits from the Rubicon hood but you have to break off the little lip and turn the spring sideways.
***Everything else from Rubicon hood is a direct swap and attaches to the Mojave hood. Side cowls will use the existing bolts from the Rubicon with the exception of the top cowl.
I've heard that my JL looks "BEEFY" haha but overall I love the look. Yeah it's not functional but that hood makes the wrangler pop in my opinion. I will slap on the rubicon decals this week and its pretty much dialed in. Sorry for the rant but wanted to give out the true part numbers for those of you that are interested in the Hood swap.
Stalking from the JT forum....that hood sure looks great
t.i.
LA
Wrangler buying soon
Hey Everyone,
Parts / Part #
Hood 68338381AC
Bezel 68398765AB
L/Seal 68405001AB
R/Seal 68405000AB
F/Seal 68295588AB
Needs more pics please. This looks badass
WorkingMan
Tim
Arkansas
2019 Jeep Wrangler Sport S
Hey Everyone,
Parts / Part #
Hood 68338381AC
Bezel 68398765AB
L/Seal 68405001AB
R/Seal 68405000AB
F/Seal 68295588AB
I like it. Nice looking Jeep.
cosmokenney
Cosmo
Auburn, CA
2019 JL Wrangler
Hey Everyone,
Parts / Part #
Hood 68338381AC
Bezel 68398765AB
L/Seal 68405001AB
R/Seal 68405000AB
F/Seal 68295588AB
Pretty nice. Is the vent actually functional?
acsak
Alex
Michigan
2019 2-door Wrangler JL Rubicon (Manual Transmission)
Hey there, love your 2 door. I have a silver Rubi-2 and have thought about swapping for a sport hood because I don't really care for the Rubicon lettering. However, I've cut the bottom out of the louvres to make them functional and really like having the extra heat dissipation. I know the Mojave vent is not currently functional, but is there an easy way to make it functional by cutting through the plastic? I guess I could just get the lettering removed - wonder how easy it is to do that.
Last question: what kind of wheels are there? I'm rarely a fan of aftermarket wheels, but I do like those!
kharland17
kharland17
Kyle
San Carlos, CA
Went topless over the weekend. Check it.
kharland17
kharland17
Kyle
San Carlos, CA
there is three plastic clips that you can cut off and air can come through. I was thinking about ordering another bezel and cutting it to see what it does. I'll post some photos of the bezel.
as for the wheels they are the stock 392 wheels. 17 inches +44 offset, same as stock rubicon wheels.
Whaler27
Alex
Oregon
Saving the world :-)
Thanks for posting this, Kyle.
For those who like a scooped-hood look, but want an alternative that is actually functional (and less than half the cost) the S&B cold air intake kit Is available, easy to install, and provides cleanable/replaceable filters.
kharland17
kharland17
Kyle
San Carlos, CA
heres a video that someone posted about the Hood bezel coming apart.
talks about it at 10:12
sstuner
Ray
Northern Virginia
2018 Jeep JL Sahara
On the hood hinges, how easy/hard was it to remove the torx bolts?
kharland17
kharland17
Kyle
San Carlos, CA
They are pretty snug, be patient, it’s like the paint bonded to the hinge. It’s not though. Make sure it’s a T50 you’re using.
t.i.
LA
This looks badass. Any issues have you run into after the install?
Northridge4x4
