AnnDee4444
No worries Steve, I'm working through it too.That's true, but the ECU will be in both open and closed loop throughout a given drive cycle, so it must not reference the MAP at all in closed loop. Otherwise the piggyback would need to switch off depending on which strategy the ECU is in.
I'm honestly surprised piggyback systems work at all on these ECUs/engines, given how complex the programming is and how sensitive everything is to modification.
Thanks for working through that logic with me @AnnDee4444. I'm sure a Google search would have solved it, but where's the fun in that?
Thanks,
-Steve
I envision the piggyback working by reducing the peak voltage of the MAP sensor so that it never actually reads peak boost (at least until the piggyback wants to limit it). This way the engine would be in a portion of the VE table would still be somewhat close, and the tune would allow the fuel/timing needed for more power. Example: if peak manifold pressure allowed is 25 psi, the piggyback would not allow a signal greater than 24 psi. Everything below 24 psi would be unchanged ant the motor would operate as normal. The piggyback could also make 26 PSI output the value for 25 psi, so that the boost doesn't get too uncontrolled. Fueling is probably off, but the ECU won't care due to this condition only existing in open loop (where the O2 sensor not read).
Again this is just my current theory, feel free to make suggestions or correct something.
