jerrygcoffey
- Jeramiah
- Mar 10, 2019
- Denver, CO
- 2018 JLU Sport 2.0T w/ eTorque
- Occupation
- Software Engineer
Is there a danger of back flow into the engine when the Jeep is in steep incline situations off road?Ask and you shall receive
Great news everybody: this catch can kit is now on pre-sale AND we're giving one away! Check out the last post below for our final round of testing (it's a long one) and click here to enter the contest! If you're dead-set on buying a kit, place your order and enter the contest too—if you win, we'll simply ship your kit for free!
Oh, and here's the link for the pre-sale : Mishimoto 2018+ Jeep Wrangler JL 2.0L Baffled Oil Catch Can Kit Pre-Sale
Thanks!
-Steve
Everyday Exploration – Oil Catch Can Kit, Part 4: Final Design
If you’ve ever started something new or made a momentous change in your life, you’ve heard some version of the old cliché, “Life isn’t about the destination, it’s about the journey.” While I agree with that sentiment, anybody who’s conquered a major challenge can tell you that, sometimes, the destination is the best part. There’s nothing quite like the feeling of accomplishment you get from seeing something through to the end, no matter how long the journey is between.
When we last talked about our 2018+ Jeep Wrangler JL 2.0T catch can, we were just beginning our exploration and journey to a successful product. Our proof-of-concept kit had collected a substantial amount of blow-by on the CCV side but triggered a check engine light in the process. A quick look into the engine’s computer revealed that the catch can was causing too much restriction in the CCV system and the sensitive crankcase pressure sensor was having none of it. Over the next 10,000 miles, we would build 10 more iterations of our CCV kit and spend countless hours striking a balance between flow and function.
The first step in this process was to determine if the issue was due to our lines or the catch can itself. To do that, we began simplifying the system and changing parts one by one. When we developed our high-flow catch can for diesel applications, we learned that the most restrictive part of our compact catch can is the bronze filter on the can outlet. This filter normally catches larger pieces of carbon and helps further condense vapor in the can. If removing it solved the CEL, we would need to come up with a high-flow alternative to serve the same purpose. Our first test entailed removing the filter, reinstalling the can in its original position on the firewall, and driving 1,000 miles. The next morning, however, we already had our answer.
...Continue Reading>>>
