Method Race Wheels... 701, 703, or 704? (In matte black)
  • Total voters
    241
the.jl.adventure
the.jl.adventure
JJ
Grand Rapids
2019 Jeep Wrangler Rubicon Unlimited
Executive Chef
It really depends on the tire of interest, maxxis will peel off very easy with no bead lock due to the side wall thickness (1”)... and most hard trails, if it does not, consider it as luck... just my experience...
very good point! Tire choice does matter.
ifonline
Ian
Georgia
Small Business Owner
the.jl.adventure
the.jl.adventure
JJ
Grand Rapids
Executive Chef
What lift, if any, do you have installed? Why did you opt for 0 offset vs 25?
Decided on zero offset to clear 35s & 37's, the zero offset allows clearence for quick disconnect swaybar links and prevents the tires from bumping into control arms. Plus the stance is great with zero offset, adds some stability.
Yes on the lift, synegry 2" lift (3" total lift from stock).
ifonline
Ian
Georgia
the.jl.adventure
the.jl.adventure
JJ
Grand Rapids
Executive Chef
Ah, ok. That makes sense. I am looking at these wheels along with two others (see: https://www.jlwranglerforums.com/forum/threads/assistance-with-wheel-fitment-on-21-rubicon.74009/), and I'm starting to lean towards these.
Thanks.
Took a look at that thread, I would highly suggest the method wheels. Those other two wheels you have listed add a TON of weight comparatively. Rotational weight will really drag down your acceleration and braking.
If you go earlier on in my Instagram feed you will find a ton of detail about the method wheels and what I did to finish up the back wheel to make it look nice and clean around the camera.
Instagram: i.am.anti.gravity
ifonline
Ian
Georgia
So the wheel fit without issue but you added the pipe sleeve to dress it up, correct?
ifonline
Ian
Georgia
Nice. Thanks.
Krondor
Gary
2018 Jeep Wrangler JL - Punk'n Edition
Still love these wheels!
Jeep Wrangler JL Method Race Wheels... 701, 703, or 704? (In matte black) IMG_3536.JPEG
Here they are after a quick dip to clean them up. Got another two for my trailer, that will be built eventually.
the.jl.adventure
the.jl.adventure
JJ
Grand Rapids
Executive Chef
Looks sweet! Epic idea to match the trailer wheel to the Jeep, that's going to look awesome!
