MHSL
do you think MC 2.5 lift will require a DS? with FALCON 2.1 shocksYou will definitely want to unhook our sway bars and double check before going wheeling... I replaced mine due to clearance issues.
Depends on several factors. Do you wheel with your jeep? Will you unhook your sway bars? What length are your shocks? If you plan to do any of those things then YES, you should change out the front drive shaft to avoid any issues.do you think MC 2.5 lift will require a DS? with FALCON 2.1 shocks
Looks like the Falcon 2.1 fronts are 17.90" Compressed and 27.60" extended.do you think MC 2.5 lift will require a DS? with FALCON 2.1 shocks
Just wanted to circle back to this. I asked 4WP about it and they said they can add bump stops if needed. I have a separate thing Iām adding tomorrow so Iāll be at 4WP for them to inspect up and down travel. But I was just looking and I do have bump stops installed. This whole time I thought I didnāt but they are there and looks like at least 3 inches. So now Iām more confused. Do I need more or different kind of bump stops or do I need something else? Sorry Iāve never gone off roading so this is still new to meSorry for the delay, been slammed at work the last couple days.
No, but as @hoag4147 said, you have super limited uptravel, plus your using the shocks as bump stops. Probably scarier, you are not only driveshaft limited, I bet you are brake line limited since they left the stock bracket on the LCAs.
Using @AnnDee4444 ās data, the front shocks should be 17.5-26.25 travel.
Up, stock bump metal to metal is 16.25, plus 3ā added bump, so your bumps are 19.25. Shocks compressed are 17.5+3 upper + 1 lower (guessing on the lower). Thatās 21.5. That means you bottom out the shock 1.25ā before the bump stop, and thatās bad.
First, get the LCA brake line brackets cut off, or at least unbolt them. Thatād be dangerous if they got yanked out.
I think you have enough bushing to run the lower brackets without the uppers. IF they add an inch, that makes you safe up to 18.5, so good with about 2.25ā of bump, 2.5ā bump is probably the sweet spot, but the current 3ā would be fine. That would give you 27.25 at full droop and youād give up some travel, but would solidly be safe with stock driveshaft.
3ā front and rear is what you have, that is plenty. Iām running 3ā front and 2ā rear and considering dropping an inch in the front.Just wanted to circle back to this. I asked 4WP about it and they said they can add bump stops if needed. I have a separate thing Iām adding tomorrow so Iāll be at 4WP for them to inspect up and down travel. But I was just looking and I do have bump stops installed. This whole time I thought I didnāt but they are there and looks like at least 3 inches. So now Iām more confused. Do I need more or different kind of bump stops or do I need something else? Sorry Iāve never gone off roading so this is still new to me
Shit, Iām a retard. Weāre actually vacationing in Moab in a rental 4xe and Iāve been drinking.3ā front and rear is what you have, that is plenty. Iām running 3ā front and 2ā rear and considering dropping an inch in the front.
Lol! That's commitment - vacations to Moab, awesome, rents a Jeep, great. But can't be just any Jeep, it's a 4xe!Weāre actually vacationing in Moab in a rental 4xe and Iāve been drinking.
Edit: surprisingly, the 4xe was the only one on Turo at Montrose, and was $100 cheaper per day than an enterprise SUVLol! That's commitment - vacations to Moab, awesome, rents a Jeep, great. But can't be just any Jeep, it's a 4xe!
Now.. why didn't you drive yours there? ;-)
Yeah itās amazing how little they knew about it. They did their look and said I need to take off either the top or bottom bracket because thereās not enough travel. Which is what you said way back when I got it installed. If I didnāt ask here I wouldnāt have asked them. Not sure how they install these things and donāt look at things like that. I have to go back in a week for something else so they said theyāll take off either the top or bottom brackets in the front. They said back is fine but now I donāt know.Shit, Iām a retard. Weāre actually vacationing in Moab in a rental 4xe and Iāve been drinking.
Looks like my original concern was the amount of uptravel left in your shocks. Look at the difference in the shock shaft and the amount of gap between the bumps and the stops.
Ready for clear.Trying to decide if I like my paint plan for the MC diff cover. Iāve got two colors down so far. Plan right now is to do black on the ābackgroundā. So it will leave āgoldā on the left and top parts of the M and Surf Blue on the right with a āGoldā outline on the slope.
Gold color is the Duplicolor two stage Metal Cast Yellow Anodized.
Any thoughts?
