Silent Panda
- Jason
- Jan 20, 2019
- Salt Lake City
- 2018 JL Rubicon
Update #8 in my 2 door JL Rubicon build series...installing a Metalcloak UnderCloak. I've decided to start to posting the updates into the section of the forum that matches each new update.
Previous updates and the original build thread:
The build - https://www.jlwranglerforums.com/forum/threads/silent-pandas-2-door-rubicon-build.25628/
Update 1 - https://www.jlwranglerforums.com/fo...-build-update-metalcloak-inner-fenders.31381/
Update 2 - https://www.jlwranglerforums.com/fo...n-build-update-2-metalcloak-bump-stops.34124/
Update 3 - https://www.jlwranglerforums.com/fo...r-smarts-yeti-xd-drag-link-and-tie-rod.34837/
Update 4 - https://www.jlwranglerforums.com/fo...lcloak-lower-shock-relocation-brackets.36973/
Update 5 - https://www.jlwranglerforums.com/fo...bicon-update-5-z-automotive-tazer-mini.37354/
Update 7 - https://www.jlwranglerforums.com/fo...on-update-6-1350-goodness-from-je-reel.40392/
Update 8 - https://www.jlwranglerforums.com/forum/threads/rcv-front-and-rear-axle-install.46606/
During the install for my 2 door, there were a couple of steps that were not in the instructions. Hopefully others that bump into these gaps, will find my post helpful. I did alert Metalcloak to the omissions and was informed that they will be addressed.
Before getting into the missing steps, I have a share a pic of the stock diff skid plate in top of the Metalcloak replacement. Like the axles, I know some portions of the Jeep have to be made to a budget. I just wish that more of the budget was allotted to protecting the tender bits underneath the Jeep.
Item 1:
Hole H1 on the diff skid plate install (see below) needs a hole drilled in the frame rail and the included rivnut needs to be installed. A step drill bit is what i used.
Item 2:
There are 2 studs on the front edge of the factory gas tank skid that need to be cut off. I heard it is possible that some parts have studs and some have nuts and bolts. As you can see behind my hand...the stock skid has seen a few touches.
Item 3:
On the battery skid installation steps, there is a bracket that needs to be removed. It is this bracket:
The finished Undercloak is a very robust system of interlocking and well supported plates. There is no doubt that the Undercloak system will provide far better protection to my investment than the stock parts.
Item 1:
Item 2:
Item 3:
