GregorioJL
- Greg
- Jul 13, 2020
- Germantown, MD
- 2018 Jeep Wrangler JL
TLDR: The MetalCloak fenders look awesome and are built like tank, but man you are definitely going to earn these. I learned a few things that may make the process easier and quicker, hopefully someone will find it helpful.
The installation documents are pretty good, so I'm not repeating them but here they are:
https://www.armoredworks.com/metalcloak/instructions/JL/II-6200 JL-Overland-Front-Fender.pdf
https://www.armoredworks.com/metalcloak/instructions/JL/II-6400-JL-Overland-Rear-Flare.pdf
Rear fender installation (Jason Laverty)
www[.]youtube[.]com/watch?v=KfA0AivoulU
Details after the obligatory photos:
Fender removal
Removing the factory fenders is easy. Rear fenders have 0 bolts, front fenders have 4 bolts each. If you don't have a panel tool to remove the plastic clips a sturdy smooth scraper and diagonal cutters/needle nose may work just as well. Take some time to clean the entire area thoroughly. If you have custom rock rails, these may need to be removed temporarily for front fender installation.
The rivet nut installation tool
20 of the bolts attach to 1/2" "rivet nuts". These nuts are installed using a "tool" that is a bolt, fake nut with no threads, and a star washer. Turning the bolt while holding the nut stationary collapses the rivet.
A small number of rivnut holes in the rear have interferences (other panels) behind the main body panel. When drilling, you only need to drill as deep as the rivnut. Using some of the washers to shim out the tool can make this easier.
When installing the rivnuts, lubricate the tool generously each time. You aren't making that many turns, but it is metal-on-metal and you will want any advantage you can get. There is about 1/2 turn easy, 2 or 3 hard turns, then 2 or 3 easy turns before it is completely collapsed.
I installed several of the rivnuts as described in the instructions and Jason's video, so it is technically possible. But it's a huge PITA and I absolutely hated it. It's too awkward and flops around a lot. The perfect tool here is a 1/2" impact wrench on medium because it's putting force directly on the bolt. 4 or 5 zaps until you get through the hard part, and you're ready to finish off with a normal ratchet. I realize most people don't have an impact wrench or want to buy one. Maybe borrow one or rent one? Otherwise, having another person to hold the wrench on the fake nut will make this much easier for you.
The holes
There are 14 holes to drill on each rear fender, and 13 on each front fender. Most holes exist and will be enlarged, a small number drilled from scratch. Do yourself a favor and buy a new 21-bit kit, preferably the titanium bits. The 6 front rivnut holes will need to be drilled in 1/8" steel, so get 6 additional bits for each pilot hole (I used 3/32").
It's critical that the rivnut holes be perfectly circular, and no larger than necessary. The instructions specify 17/32" but you will not have that bit.
I found that using an Irwin conical grinding bit did a much cleaner finishing job instead of the last bit (3/8" regular nuts/bolts, 1/2" for the rivnut holes), and can easily go from 1/2" to 17/32" for the rivnut holes.
The front fender rivnut holes
The six 1/2" front rivnut holes are drilled into the 1/8" steel subframe. Upside down. These aren't something you can tap with a center punch once or twice and start drilling. What I found worked was two punches. An Irwin awl punch and a normal center punch. Use a file to make and keep both of these as sharp as you can, the awl punch needle sharp, and put a flat screwdriver like edge on the normal center punch.
Use the awl punch and strike it 5 times as hard as you can, re-centering the punch each time. Then use the center punch with a flat edge at a slight angle with the corner edge into the dimple you created, striking it 5 times as hard as you can, re-centering the punch each time. If you have done this properly, the pilot hole can be as quick as a few seconds or a couple of minutes. If not, make a few 30-second passes with the bit, oiling it each time. Then repeat the punch process. Continue until pilot hole is finished.
After the pilot hole breaks through, go through each bit size with oil all the way to 1/2". The instructions specify to remove the bracket while drilling, however I thought it helped to leave it on because it helps you see if you are off-center and need to correct before it's too late. The bracket must be removed for the last two bits 3/8" and 1/2" and the conical grinder bit to get it to 17/32".
Mounting
After you finish the rivet holes and install the rivets, mount the fender on them. For the non-rivnut 3/8" holes, insert a 3/8" bolt and ensure they all pass through with no interference. Many will not. Score the metal surface with a blade so you know where to use the conical grinding bit to adjust these until they all pass through cleanly. Remove the fender and make the necessary adjustments. The 3/8" regular nut/bolt holes you have a lot more slack than with the rivnut holes so don't worry if they look a bit weird. This is a good time to brush/spray paint on the holes and let them dry. A few 3/8" holes getting the washer on is difficult to reach. You may want to use the tiniest dot of super glue to stick the washer to the nut to install these properly.
Captive nuts
The front fenders have 2 captive nuts, and 1 on the rear. These are for the recessed flat steel bolts on the front and rear of each fender. If you get the black powder coat, these are baked in an oven. There must be some dust because the captive nuts had particulate matter in the threads that interferes with the bolts. Use swabs and goofoff to clean. This may need to be repeated multiple times. Or just leave the swabs in there to soak for a while to loosen it up.
Underside of fender
If you spend time on gravel roads or roads that have a lot of harsh treatment in the winter, Rustoleum undercoat on the underside of the fender may be a good idea. Easier to do a couple of coats a few days before installation.
Wiring
For the front fenders you will need these diagrams:
https://www.jlwranglerforums.com/forum/threads/jeep-jl-wrangler-wiring-diagrams.19185/
LAMP - DRL - LEFT (BASE) CONNECTOR DETAILS - Wiring Diagram
LAMP - DRL - LEFT (PREMIUM) CONNECTOR DETAILS - Wiring Diagram
LAMP - DRL - RIGHT (BASE) CONNECTOR DETAILS - Wiring Diagram
LAMP - DRL - RIGHT (PREMIUM) CONNECTOR DETAILS - Wiring Diagram
On the fender side, white is ground and black is hot.
The fender kit includes butt connectors. If you use these, do yourself a favor and use a decent crimper. The supplied connectors are much harder to crimp than the usual heat shrink style connectors. It would actually be possible here to use solder/heat shrink if you want, because you will be repurposing part of the cable from the factory fender that includes the nice Mopar connector.
The LED/wiring does not accommodate the turn signal fault wire. I have a Tazer and disabled the LED fault, but the turn signal warning appears briefly during ignition and it makes the fast blinking sound when turning, but externally it blinks normally.
Final thoughts: If I had to do anything over again, maybe not installing these in a parking lot when it's 95 degrees outside. Also I did both rear fenders in one day, probably do one fender each day. The kits didn't include anti-sieze but you really should use this on every bolt. A tube of Liquid Wrench dielectric grease is about $6 so you should have that handy.
Fender removal
The holes
Mounting
Captive nuts
Underside of fender
Wiring
