Roky
That looks like your control arms are not adjusted the same side to side. I would double check to see if both sides are the same. What’s your caster set at ? When the bumps don’t line up, that’s usually a pinion angle thing. If you can, put tan angle finder on the flat of the diff like in picture, see what it says.I know this is an old thread but I have the exact same issue as this. My lowers are already at 24 1/2" and Uppers are at 19 3/4". I know that my pinion angle is down about 2 degrees already.
But my biggest thing is I am at ride height and doesn't really look to be centering up on the bumps tops. Is this normal?
