Fire Burns
I recently purchased a used Metalcloak Front Trackbar. According to Metalcloak, installation requires enlarging the hole in the axle side (right side) trackback bracket, thus allowing fitment. From the Metalcloak instructions:
"MetalCloak uses an over-sized forged housing for additional strength; the factory window pocket may need additional clearance for optimal fitment. Use a die grinder and cutting bit to enlarge the existing window in the factory track bar bracket. It may help to grease the outside of the track bar bushings to make the install into the track bar brackets easier."
This was know to me when I purchased, but the idea is slightly bugging me. For others is been enough to go with another manufacturers product altogether. Still yet others decided to clearance the trackback DuroTrak bushing housing itself rather than the pocket, though I've not seen this mod in detail.
Rather than debate the merits of the Metalcloak trackbar itself, I'd love to hear opinions from people who have installed them. Did you clearance the bracket pocket? Did you clearance the bushing housing? Why did you decide to do one or the other? What mod would be easier? Pros/cons, etc.
One thing is that I got this trackbar for only $100 so I don't mind modding it if its prudent. On the other hand, I paid multiple thousands of $$$ for my JLUR and I'm a little more reluctant to mod a bracket when one of the whole points of adding a trackbar is to eliminate flex at this location. Wouldn't clearance the bracket create an opportunity for unwanted flex?
Thanks!
Fire
FYI: Metalcloak instructions for their front trackbar (to include pic of what I'm talking about) can be found here: https://www.armoredworks.com/metalc...NSION/II-7616-JL-Front-Durotrak-Track-Bar.pdf
Thanks!
Fire
