Metalcloak 3.5 - Rocksport - 38” Patagonia - Mopar beadlock s
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
Free shipping got you too? LOL!
Shoot! I wish. I bought mine a couple weeks ago and they weren’t offering it. I wasn’t worried about being caught up with the Black Friday sale and not get the lift early enough. We’re bringing the Jeep home on stock suspension and 37s. It’s going from the trailer straight to the lift for the lift.
Brett
4xnaz
Tim
Phoenix, AZ
www.instagram.com
2018 JLU Rubicon
Exact same set up here. 3.5 Metalcloak, 38s Milestar Patagonia. For people wondering about fitting in the garage, no problem with my standard garage door opening of 6'10". No noticable power loss after using Tazer Lite but lost 8th gear.
leanxormean_stack
Ali
WA
2019 JLU
Software Eng.
Beautiful colors and set up.
Zenk
Zenk
Northern Virginia
Awesome!
What is your wheel width and offset? Any bump steer?
TDS
Travis
Milwaukie OR
2019 Rubicon
Commercial Project Superintendent
Thank you so much for the garage measurement!!! Was totally wondering if it was going to fit, Guess the wife's car will still be stuck outside,LOL
jruss
Josh
Greater Baton Rouge Area
2018 Jl Sport Unlimited
I need a way to mount my 38” spare... any suggestions? Would like an inexpensive solution.
Not 100% sure but I think those are bead looks not bead locks. I could be wrong but if you were charged for the lock rings you might want to triple check. Cool Jeep.
jruss
Josh
Lost a gear of your transmission but did not lose power? I’m confused.
Zenk
Zenk
Northern Virginia
Yes and no... they are currently in the bead look configuration. As you probably know, I can convert them to beadlocks with the optional bead rings. I wanted to run them this way while I finish the rest of the Jeep, beadlock rings are on the wish list and will be added later.
ExitLeft
Wes
Philly ‘burbs
2003 Jeep Wrangler TJ
Looks great @Zenk
Question for you: any issues running those mopar wheels with the MetalCloak lift? I think those wheels have 5.8” backspacing. We’re you able to use the MC front shock relocation brackets with those wheels? How about the extended rear sway bar links?
Thanks. I’m seriously considering this, but I’m locked into 17x8.5” wheels with 5.2” backspacing. MetalCloak seems to think 4.5” backspacing is needed to run their kits as designed.
4xnaz
Tim
Phoenix, AZ
www.instagram.com
2018 JLU Rubicon
Yes, 8th gear will make an appearance from now and then, on the freeway....downhill. Acceleration hasn't changed, which I was referring to when I said no real power loss. And with 7th used mostly at highway cruising speeds, RPMs are still hovering around 2000.
Zenk
Zenk
Northern Virginia
Looks great @Zenk
The Mopar Beadlock has a backspacing of 4.4" (12mm offset). It is 8" wide in the beadlook config, and 8.5" wide is the beadlock config.
I'm having zero issues with this wheel on the MC 3.5 GC lift.... BUT... this wheel is a little on the narror side for the big Patagonias (recommended width is 11").
