DIY Metalcloak 3.5" Game Changer Lift Install and Review
swampcat14
Midlothian, TX
www.c4x4.com
Google Data Center Maintenance Program Manager
In a lot of ways, owning a Jeep is like having a kid, right? For one, they're expensive to buy. Now you may be saying, "I didn't buy my kids!", to which I reply, "Yes you did." You either adopted them, or you walked into a hospital one day and left with a kid (and a large bill). I dunno about you, but to me that's a purchase, haha. But I digress. Also like kids, Jeeps are expensive to feed, time consuming, fun, and they almost always go through puberty. Changing from their natural-born form into a bigger, better version of themselves.
Project Swampcat was an early bloomer, hitting her growth spurt after only a couple months of being free in the world. Choosing a lift is never an easy process. There are many things to consider... intended use of the Jeep, tire size, available budget, manufacturer reputation and quality, lift height, body or suspension, adjustable control arms, etc, etc. The finer points of lift kit design and selection warrant their own article (or book, haha). On top of that, since Swampcat is a JL, which has only been available commercially since January, we were limited to a few reputable aftermarket companies that had released lift kits. We also had a big trip to Colorado coming up, and of course I wanted to take the Jeep, so we needed to have the lift in and sorted before that. Long story short, we ended up going with Metalcloak and their 3.5" Game Changer kit, but instead of their 6-pak shocks, we opted for an early-release set of Falcon 2.1 Series Monotube shocks specifically for the JLU. This setup checked all the boxes for us. In addition to the suspension, we fitted 37" BFG KM2s on Hutchinson Rock Monster Beadlock wheels in Argent. The Argent color perfectly matched the 'silver' accents in the Jeep exterior color scheme, so that turned out unexpectedly well.
I did the install in my garage, over about 5 days. That's longer than it'll take you, because I was shooting videos and pictures as I was going, and I also installed a full set of skid plates, step/sliders, and wheels/tires at the same time (keep an eye out for future articles on those). Metalcloak has put together a pretty decent installation procedure, and says it should take 6-8 hours. I'd say that's accurate if you've done lift kit installs before and have access to a professional shop. If you've never done a lift before, or you don't have access to a shop, I'd budget 10-12 hours.
The lift can be done with basic hand tools, but of course having professional grade stuff makes it easier and faster. Everything is bolt in, but there are a couple spots where drilling/grinding is necessary. These are the front track bar bracket, front lower control arm brackets, and front lower spring perches, and in each case you're just widening or enlarging existing holes (be sure to repaint any bare metal).
The only really tricky part throughout the install is making sure you've got the axles properly supported when swapping out the control arms and track bars. Without proper support, gravity will do its thing, which could cause damage to parts of the Jeep or your body, neither of which is desired. It also helps to have some experience adjusting axle position with jacks and jackstands to get the arms lined up to put the hardware back in. These things aren't hard, but they can take some patience and careful forethought to execute well. Swap the control arms one at a time.
Overall, the whole thing was pretty straightforward. The instructions didn't include any torque specifications, but I found the factory torque specs here. The control arm lengths provided by Metalcloak were good enough for me to get to the alignment shop. I highly recommend going to an alignment shop that does aftermarket Jeep suspensions. Adjusting these control arms and track bars will require removing one side of them from the Jeep, so it's best to have an alignment tech who has experience with these. Also, just as an FYI, most alignment shops use alignment racks that are NOT rated for any tires larger than 35" (and YES that makes a huge difference). So, if you have tires larger than 35's, make sure your shop has a rack that is rated for them.
After everything was installed and aligned, I drove it back and forth to work for a couple weeks, and on-road performance is better than stock, smooth as butter at highway speeds. I had the dealership do the software update to correct my speedo for the larger tires (and make sure my 8-spd auto shifts properly), and I'm still averaging 17.5 to 18 MPG, which is crazy for a lifted Jeep on 37s. Then we took Swampcat out to the 2018 Crawl-4-Christ in Disney, Oklahoma and I could not be happier with the off-road performance of this setup. It tackled everything I tried out there, and just kept begging for more. Slight rubbing on the plastic inner fender liner for the rear tires at full stuff, but otherwise flawless. I didn't get into the crazy rock crawling obstacles (anything that had very high potential for body damage), but Swampcat performed better than my JKU did with 37"s, coilovers, long-arm, 1" stretch, RCV chromoly axle shafts, high-angle driveshafts, Dynatrac axles, etc, etc. That was just the shake-down run, though. Last month, I took Swampcat and the family on a 4,000 mile road trip through Oklahoma, Texas, New Mexico, Arizona, Colorado, and Kansas. That majority of that was paved (we tried to avoid major highways), but of course we hit the trails in Colorado. For three days we traversed one mountain pass after another, hitting all the major trails except Black Bear Pass an Poughkeepsie Gulch (due to weather). Here again, Swampcat tackled everything with ease, and we pulled back into our driveway with nothing more than a slight steering wheel adjustment needed.
My goal for Project Swampcat is a family-friendly overlanding Jeep that is a 'Jack of All Trades, Master of None'. After installing this lift and driving on it for ~5,000 miles, I can satisfactorily say that this suspension setup exceeds that goal. I may upgrade the shocks to Falcon 3.3 Series (when they're released) for easy street/trail tuning adjustments and better heat management. For now though, I'm completely satisfied with the post-pubescent version of this kid.
CME-ROCK
Chastity
Houston
2018 Jeep Wrangler JL
Check out my article and let me know what you think!
awesome article! so far I only did the 3.5 EVO Enforcer stage 1 with shock extensions and I changed out my lower control arms to the metalcloak and boy did they make a HUGE difference in ride stability on the highway at high speeds! SOOOO much better than the factory. will be adding more metalcloak for sure LOL
imapseudonym
So Cal
2018 JL Hella Yella Rubicon
We were looking at this for our JLU if/when we get one :D Expensive as heck but the quality seems so good. Thank you for the write up and post more reviews of it the longer you have it!
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Thanks! Yeah that was one reason why I went with MC over EVO (the control arms) and MC has a true dual rate spring.
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Thanks! Will do! I've put about 5,000 miles on it so far and it's still going strong!
gwk
Grant
Massachusetts
2018 JLU Rubicon
Thanks for a fantastic write-up. This is the exact setup I'm thinking about.
I've seen reports of driveshaft issues at 3.5" (tearing of the boot offroad), and I've been wondering if I need to budget for that at the same time - did you see any of that or have any other problems?
Do you intend to post the rest of the pics and vids you mentioned somewhere? I'm also wrestling with whether it's possible (or wise) to do this myself vs paying a pro, so I'm interested in the whole process.
Also, if you have before and after pics (ideally positioned similarly to make comparisons easier) I'd love to see them. Trying to visualize the outcome is hard.
Nice work (both the Jeep and the article)!
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Thanks!!
The only issue I ran into driveshaft-wise was during the install. I did the lift after having installed a full set of Rock Hard 4x4 skid plates. Short version, the skids prevented the driveshaft and front axle from drooping enough to get the driver's side spring out easily, so I had to use a spring compressor. Not a big deal. As for off-road, I haven't seen any issues with the driveshaft.
I'm working on editing the video now. This is my first DIY video, so it's a learning process, but it should be done soon. It'll go up on my YouTube channel when it's done. I'll post a link here though.
I'll look for a good before/after angle to post and get it in here later today.
gwk
Grant
Massachusetts
2018 JLU Rubicon
It would be nice not to have to immediately upgrade the driveshaft too. It's much cheaper than the lift itself, but I expect the labor is significant.
I may have similar skidplate issues, given I just put the full Metalcloak skid system on it (looking forward to going out Sunday more fearlessly than before). On the other hand, if I have a shop do the lift it'll be the same guys that put the skids on, so they're not likely to complain.
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Driveshaft swaps are pretty easy actually. Just a few bolts on each end, then it drops out. Takes 10-15 min.
Chocolate Thunder
Jeremy
Thanks!!
Could you please explain that to me (bolded)? Are you saying that the skid plates restrict the amount of downward axle and suspension travel?
Chocolate Thunder
Jeremy
Do you have any photos of the Metalcloak skids installed? Please post your thoughts after you’ve gone out with then. I’m considering them and the RockHard ones. Thanks.
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Yes, but only during the installation. When installing a lift, you have to get the axle to droop a lot in order to get the springs out. We're talking much more droop than you would ever see on the trail (unless you're doing a long arm, stretch, or taller than 4" lift). You could also get the springs out using some spring compressors, but these are tricky to use and can be very dangerous if not used properly. So, if your lift comes with new control arms that you have to replace anyway (which the MC kit does), they will typically have you droop the axle out to remove the springs, rather than use spring compressors.
The skid plates do not restrict down travel under any driving condition because this is limited by other components (shocks, control arms, etc).
I have the Rock Hard skids installed (not Metalcloak). You can see pics of them in my build thread (linked in my signature in red at the bottom of this post).
gwk
Grant
Massachusetts
2018 JLU Rubicon
I don't have any pics yet, but I may take some this weekend. The guys at the shop asked for a report after I'd done a run with them, so I may snap a couple afterwards (with scuff marks presumably). They're real pretty for something nobody ever sees :)
Csward12
Chad
Corona, Ca
2018 Jeep JL Rubicon
Law Enforcement
I j
I just received this kit, and forgive me if I missed it in your post, but what are you doing with the brake lines now?
I’m installing 4/6.
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
I'm using the stock brake lines. The Metalcloak installation instructions are pretty clear about what to do with them, but you basically end up zip tying them back into the factory location. Jeep built in enough excess hose, and Metalcloak engineered this lift well enough to allow for the full droop.
