Jaredhoefsmit
How are the 6pak shocks for higher speed trails, fireroads, general overlanding? Looking for more of a faster build, lots of travel, speedbumps/hydrolic bumpstops, etc.
Did you already get an install? I'm going with Brothers 4x4 in Montclair. I just ordered a 3.5" Metalcloak lift and I'm going with the Rocksport Shocks for maximum articulation.I am in the 92660 zip code, can you recommend a reseller/installer in my area?
How did your install go?Did you already get an install? I'm going with Brothers 4x4 in Montclair. I just ordered a 3.5" Metalcloak lift and I'm going with the Rocksport Shocks for maximum articulation.
i suggest the aftermarket wheels option, it is links vs drop bracket in the rear for the sway bars.Does anyone know if 10% is the best black Friday deal there is?
Eta: I'm also curious about the wheel backspace selection on the website, I'm going to go with the six packs to start but plan on hutchinson rock monster wheels, should I choose the standard or six pack option for that section
My wheels are 8.5" wide with a 0mm offset, giving me backspacing of 4.75inch. Was it correct of me to choose the "stock wheels" choice since it mentions [backspacing>4.5"]?i suggest the aftermarket wheels option, it is links vs drop bracket in the rear for the sway bars.
The code is good all week long
wearethankful
if you are fire, police, ems or military use USAhero. They will contact you for verification
that’s the best deal they offer
brett
i would consult with MC directly for final verdict but my suggestion is to contact them ASAP and swap that to aftermarket wheels. You’re currently going to be receiving the sway bar drop bracket and while it works, I prefer the longer links. You’ll have plenty of clearance with 4.75”My wheels are 8.5" wide with a 0mm offset, giving me backspacing of 4.75inch. Was it correct of me to choose the "stock wheels" choice since it mentions [backspacing>4.5"]?
Thanks!
Thanks!!i would consult with MC directly for final verdict but my suggestion is to contact them ASAP and swap that to aftermarket wheels. You’re currently going to be receiving the sway bar drop bracket and while it works, I prefer the longer links. You’ll have plenty of clearance with 4.75”
brett
Thanks Brett, I'm still going back and forth with the 2.5 - 3.5, leaning hard to the 2.5 since I'm goin with max terrain flares and inner fender wells. And if I want more I can just swap springs.i suggest the aftermarket wheels option, it is links vs drop bracket in the rear for the sway bars.
wearethankful
brett
