ckuptz
I have owned a 2020 JLU Rubicon with the 3.6L engine for the past 23 months. After about 9 months and about 11,000 miles, I changed from the stock 285/70/R17 BFG K02s to 315/70/R17 BFG KO2s which I have put another 15,000 miles on. I kept the factory stock wheels. Other than having slightly slower acceleration, I didn’t notice any difference in the on-road performance and handling which I were completely happy with. The tires are inflated to about 35 PSI cold.
Yesterday, I picked up the Jeep after having a MetalCloak 2.5” Game-Changer lift with RockSport shocks, DuroSpring bump stops, and an Adams front driveshaft installed. The factory stock wheels are still being used. The lift raised the height of the Jeep about 4.25 inches. Because it conflicted with the stock muffler, the rear sway bar was removed. The installation shop performed an alignment after the lift was installed.
Everything that I had read about the MetalCloak lift was that the on-road and off-road performance was as good or better than stock. I haven’t taken it off-road yet but have driven it on-road about 150 miles. At speeds below about 45 MPH, the Jeep handles like it did when it was stock except that the shocks are firmer. Between 45 and 65 MPH, the steering starts feeling a bit loose. Above 65 MPH, the Jeep feels like it is being buffeted by winds even though there aren’t any and the steering feels even looser. Something as simple as changing lanes feels sloppy. Is this type of handling typical after lifting the Jeep? If not, any suggestions on what the cause might be? If it is typical, any suggestions on what I can do to make the Jeep handle on-road like it did when the suspension was stock?
