Metalcloak’s front diff skid sneak peek
RubiconReese
Matthew
Edmonton
That is why we stayed with hex head bolts. You should be able to get an open end wrench on the heads enough to get them off.
Why not make it recessed like you've done on the on the FAD skid plate? Id much rather sacrifice to add 3/8" or so to have the bolts recessed to prevent damage. I think most Jeeps owners has had their fair share of removing damaged bolt heads which is honestly a nightmare.
CloakedWillys
Summit Sponsor (Level 3)
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
Sales and tech support for MetalCloak
Trying to keep it from sticking so far forward to catch on. It would move the front edge about 3/4" forward to work.
RubiconReese
Matthew
Edmonton
Can someone please confirm we are supposed to fill the front differential with 1 Liter of fluid as specified in the OEM specs and NOT to fill to the new fill plug till the fluid flows out as typical. The new fill plug on the differential cover appears to be higher than the OEM cover.
CloakedWillys
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
Correct, Stock fluid fill capacity.
DLW
Bay Area, CA
2019 Jeep Wrangler JLUR
FYI, It says in the instructions:
"Note: Be sure to fill oil to manufacture specifications."
