RDiddy
Holy crap, jackpot! Thanks very much. Saving all of the above. Seriously, thanks OGNJI keep this as an iPhone note. Maybe some of it will be useful to you since you’re just getting started. Note that I have a 2dr, manual rubicon with tow package some some things may be different for you (eg diff oil weight)
Oil
5q 0w20
Diff
75w90 - front
75w140 - rear
"Flex Fill" bags are the way to go:
https://www.amazon.com/gp/product/B08KB5LTJM/
https://www.amazon.com/gp/product/B002HQGCVG/
Oil Filter
MOPAR MO-349 68191349AB/AC
Mobil 1: M1C-456A
Air Filter
MOPAR 68257030AA
Cabin Filter
MOPAR 68301863AA
Sockets
22mm lugs
13mm drain plug
24mm oil filter cap (torque to 18lbs - too tight and it'll crack)
8mm air filter
UConnect
Pull F97 to reset
Hold driver's side temperature up, temperature down and front defrost buttons simultaneously to enter dealer mode (to see version numbers)
TSBs
TSB 18-092-19 Needed so Jeep will crank on second try if AUX is dead. Don't say ESS because that TSB doesn't mention it. Say the A/C fan is too loud.
Main Battery
Northstar 48 or Odyssey 94R (94R only confirmed to fit Rubicon with tow package)
Forum recommended tires
Cooper STT Pro (these look badass with lettering out - good in snow) 285/70R17
BFG KO2 (stock)
Full Tazer Sleep Process
For some reason Joe removed some of this from latest guide. The red security bit is useful!
Once done adjusting settings, turn the ignition off, then start the vehicle. It may start and stall with the red security dot lit. If this happens, wait 10 seconds and try again, it will resume operation when it has completed its re-learn procedure. Then two sleep cycles: Shut off the vehicle, open and close the driver door and wait for a minute to be sure the dash turns off. Then start it, wait for the radio to boot up, then shut it off and open/close door and wait again.
Fuse Array
68368854AA - 100 Amp (tow package)
Fix seat if it won't recline
68485522AA Insert-Seat Position Return
68485519AA Insert-Seat Position Return
https://www.jlwranglerforums.com/fo...ld-and-lock-into-position-june-20-2019.34614/
