Media Cover Small Modification
richardya
New York
Ford Edge 2011
I have my cord protruding from the USB area all the time. I would love to have a hole in the media cover for the wire, and then I'd tighten the wire cord. (1) Anyone have experience with this, maybe a way to make it cosmetically look good with a washer type *piece to put in the hole? I would only do this if I could order a replacement in case I eventually sell the jeep or stop using the USB connector. (2) Anyone have knowledge how to order that piece from Jeep?
*Grommet as pointed out by Heimkehr
Jeep Wrangler JL Media Cover Small Modification IMG_2077
jhackathorne
Denver
'21 JLUR
While I did not run it through the front, I did cut a hole to run the cable behind and up the dash. If you are just trying to keep it closed you could do what you said or I have 90 degree adapters I can send your way. I ran a 90 degree and plugged in my cord and run it through the hole and behind the dash.
EDIT: I don't believe you can order just the cover from what I have seen others attempt. You'd likely have to replace that entire portion of the panel.
Jeep Wrangler JL Media Cover Small Modification IMG_7863
Jeep Wrangler JL Media Cover Small Modification IMG_7864
Jeep Wrangler JL Media Cover Small Modification IMG_7865
richardya
richardya
New York
Ford Edge 2011
I think youre saying it still wont close flush with a hole. I would have to cut a rectangle or something for the USB to get through. I think your right.
@Heimkehr Yes, grommet thank : )
jhackathorne
Denver
'21 JLUR
Yes, cutting straight through the front is the only way to get it to sit flat. Or remove it altogether. I don't mind how it is barely cracked on mine. I mainly wanted to conceal the cable and have it mostly closed.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
I use the one in the console (USB2), the one on the dash is for the concessional passenger.
