This thread is a great find! New 2021 2-door soft top with the alpine system. Best stock system in any Jeep I've had, but would still like more...just not a $8K system more. From reading the thread, it sounds like I should skip the 6x9's unless I go all-in on the system w/ the amps.
I do want to order before the new coupon code expires - can't believe I didn't see them at Overland Expo Mountain West.
Is the benefit of speaker upgrades without amps 'enough' more? The amp install is lengthy - would love to just swap speakers (and have another project that I need to take the dash apart for, so the timing is right).
We're keeping the factory head unit. So: Amp or no Amp?
I read through the instructions - running the wires for the amps looks to be a lot of disassembly...is that not true?The amp install is probably the easiest part of this install. The 6.5 knee speakers in the dash is the most work.
I have to take the dash apart anyways so was going to install the speakers while in there.
I was just in Utah, but not with my Jeep as it was a group hike.I have been reading about the MB Quart upgrade. I was wondering how you guys are feeling about the upgrade now that you have had it in for a while.
TO say the least I am much less than impressed with the expensive Alpine upgrade that is in my jeep. I had a JK with the Alpine and it was much better than the new system in the JLs.
I reached out to MB Quart about the sub upgrade for the JLU. According to David Kotewa from MB Quart, they are still working on it. He told me that updates will be posted on their social media.
If any of you are here in Utah, I would love to hear how your system sounds.
Can you pull the sub out from the front or do you have to pull the entire panel off? I pulled the panel off when I added in my tailgate tire mount but forgot to look closely at the sub connections.I pulled out the Alpine sub and threw in some polyfill and dynamat. Nice improvement from very short testing. The Alpine sub appears to be a very low profile quad voice coil setup. Never seen anything like it so I dont expect a sub replacement without some new wiring and/or amp from MB Quart.
You have to take the panel off because there is a screw that comes through the back of the panel into the back of the sub's magnet.Can you pull the sub out from the front or do you have to pull the entire panel off? I pulled the panel off when I added in my tailgate tire mount but forgot to look closely at the sub connections.
You do need to use the tweeter plug, MB Quart will even send you the correct adapter if you ask. It will not get you full range, I believe you get 400-20khz. They should have offered a 3.5" plus 4-5" speaker combo for the alpine soundbar. The 6x9 is basically useless but still sounds better than stock.I wish I would have seen this thread before I tore into my sound bar and installed the 6x9s. I have the alpine upgrade and just finished the install. I thought it was weird that there wasn’t 2 plugs for each harness that was supplied. Now I have barely any low end on the sound bar and no highs. I’m pretty proficient with wiring so can I just disconnect the tweeter wires on the 6x9 and make a connector that plugs into the factory tweeter plug? Will this get me back my full range of sound? Or are there 6x9s out there that have separate tweeter and woofer wire connectors but still built into one unit? I don’t want to do anything else like upgrading amps or anything. Just wanna get my 6x9 sound bar speaker working the way it should.
I still enjoy my system minus the 6x9 being a poorly thought out upgrade for us Alpine system owners. Still way better than stock though.You have to take the panel off because there is a screw that comes through the back of the panel into the back of the sub's magnet.
Are you still happy with your MB Quart setup?
https://www.jeepgladiatorforum.com/...nstall-with-custom-sub-box-behind-seat.43076/Has anyone replaced factory sub with aftermarket sub/amp in stock enclosure?
Ummm...that's for Gladiator? This is a JL forum. Unless I'm missing something.
