AnebuR
It can be done without removing the airbag or disassembling the entire dash. Passenger side took me about 15mins. Driver's side was a major pain in the ass in order to be able to get the speaker pod out without taking everything apart. The trick was to remove the leftmost screw on the support bar under the pod, as well as removing the dimmer switch and the module behind it. This allows one to access the topmost speaker pod screw. The other trick is to turn the pod in order to get it out and over the support bar, which one should be able to move a bit after removing the screws.The kick panel speaker install was stupid difficult. You could almost feel the distain Jeep must have for their owners to require the airbag be removed in order to simply access a speaker. Removed approximately 750,000 screws and ended up with 8 extra when it was all said and done. The project was worth doing, but damn those kick panel speakers to hell .
