MesaAZGuy
Cheapie Amazon deal. Matches factory texture really good. It's gonna get chipped up from rocks and crap. When it does, off to powder coat shop.
Which KC light mounts are those?Some pics to compare to the mopar if anyone is interested.
KC HiLiTES 73071, had to go through every size to get a set that fitWhich KC light mounts are those?
The texture looks almost identical, in my opinion. The bumper is a slightly rougher texture, but it isnāt noticeable unless you get really close or feel it. I tried taking some pictures just now, but itās hard to tell in the dark. Iām fairly OCD myself, and it passes muster for me.Anyone with the Grimm bar, is the texture the same as the stock steel bumper? My factory steel came with a RockHard 4x4 bar and while it looks good, the texture is different and it drives my OCD nuts. It's got a sheen to it.
Don't think the Mopar Triple-hoop is much higher (and may be even a bit shorter at the center), but the Maximus-3 XLP is a thicker diameter pipe and much more rounded inward, making the LP4 a tighter fit.Not my Jeep but shows the Mopar triple hoop with some LP4ās. Must be a little higher than the Maximus triple hoop.
Yeah, I've got the same arrangement and the LP4's just barely make it. My SLP bull bar is the same exact as the XLP, minus the outer hoops.Don't think the Mopar Triple-hoop is much higher (and may be even a bit shorter at the center), but the Maximus-3 XLP is a thicker diameter pipe and much more rounded inward, making the LP4 a tighter fit.
How is the camera view?Maximus-3 XLP Loop
The stinger looks great how does it work with the front camera? Does it block much?Great finish on the Maximus
This is the only picture I have of it.The stinger looks great how does it work with the front camera? Does it block much?
