Maximus-3
- BRENDAN
- Oct 17, 2018
- Detroit,MI
- Website
- www.maximus-3.com
- 2020 Gladiator Rubicon, 2018 JLUR, 2015 JKU
- Occupation
- Aftermarket Specialists
MAXIMUS-3 Knows Winch Plates...
* In 2013 Maximus-3 was the first company to design a winch plate to fit a Warn Zeon inside the JK 10A/Hard Rock bumper. A feat of engineering that was said to be "not possible."
* Our Winch Plate structurally exceeds all standards required by winch manufacturers.
* Maximus-3 offers a complete winch mounting system with the most accessories, options and customization.
* Our accessories are designed to be compatible with other Maximus-3 products.
* Imitation is the sincerest form of flattery - our winch plate has been often imitated/copied.
* You can count on Maximus-3 to get you out of a sticky situation.
MAXIMUS-3 JL WINCH MOUNT PLATE & ACCESSORIES
PRODUCT OVERVIEW:
Designing a winch mount/plate is not just about proving a flat piece of metal to to bolt your winch onto. A well-engineered critical component like a winch mount requires proper engineering design to obtain optimal structural integrity and making sure that it will perform when you most need it, without adding too much weight. Structured sheet metal plate is 3 to 5 times stiffer than non-structured sheet of the same thickness and hardness. It’s also important to make sure that the design is compatible with vehicle’s frontal impact safety features like crumble zones and airbags deployment in the event of a front collision.
Maximus-3 winch mount plate is an innovative compact and well optimized structural design, Maximus-3 winch mount is made from ¼” thick steel plate (not 3/16”) and is correctly formed (bent) and welded to increase bending stiffness against bending moments during use for straight pull recovery or use for down force (suck down). The plate sets your winch inboard of the bumper at optimized height to ensure correct winch line (synthetic rope) to the fairlead operating angle. We also incorporated release features at mounting points to allow proper function of front crash zones on the chassis frame in the event of a front impact.
Maximus-3 winch mount was design with DIY and ease of install in mind so that any able person with average mechanical knowledge can install it himself or herself without any cutting or use of specialized tools required. We integrated self-hold-up features in the plate to aid holding up the plate and the winch during install to make it easy on the lone one-man installer.
The system is universal to give you the freedom to install most popular winches on the market, both centered or offset set-up. Maximus-3 Winch Mount Plate was designed as a complete recovery system offering a range of optional accessories.
OPTIONAL ACCESSORIES:
Maximus-3 Performance Hawse Fairlead: MAXIMUS-3 MAXGLIDE Performance Fairlead is CNC machined from 1” thick grade 600 aluminum, which is thicker than standard fairleads. Featuring a larger radius for smooth rope glide. This is a well-balanced design of optimal function, performance and aesthetics. Available in three finishes:
* Red Powder Coat Finish (Part#: HR1013MR)
* Black Powder Coat Finish (Part#: HR1013MB)
* Gray/Gunmetal Hard Anodized Finish (Part#: HR1013MG)
Fairlead Adapter Plate: The Centering Plate serves as a relocation plate for your Fairlead to be able install your winch in the centered position in the bumper. Included in our winch mount kit (part# JL1012WM) Optionally you can use a Hook Anchor instead.
Maximus-3 Hook Anchor: The Hook Anchor serves the same functions as the Centering Plate but with the additional function as a secure anchor point/loop for your winch hook. Two color options:
* Red gloss powder coat (Part# JL1015HR)
* Black textured powder coat (Part# JL1015HB)
Filler Trim Plates: The Filler Trim Plates will trim the area around your winch and fills the gap between the bumper and the grille to cover the chassis frame for a more finished install. Two styles available:
* Zeon Trim Plates - for Warn Zeon series winches (Part# JL1017FZ)
* Standard Trim Plates - for small body winches (Part# JL1017FS)
D-Ring Loops: The D-Ring Loops will give you secure points to attach a pair of recovery D-Rings. The loops are made from ½” thick steel and mount to the bottom side of the winch plate (required for install) Two color options:
* Red gloss powder coat (Part# JL1022DR)
* Black textured powder coat (Part# JL1022DB)
Maximus-3 Front Tow Loops: The Tow Loops will give you secure connection points for tow bars to flat tow your Jeep behind an RV or a Motor Home. Made from 5/8” thick steel these Tow Loops mount directly to the chassis frame and fits 7/8” connection pin. Available in two colors:
* Red gloss powder coat (Part# JL1025TL)
* Black textured powder coat (Part# JL1026TL)
KEY FEATURES & SPECS:
* Designed specifically to fit 2018+ Wrangler JL with Rubicon Steel Front Bumper
* Made of a one-piece heavy gauge ¼” thick steel plate (not 3/16”). Process: laser cut, press brake, & welding
* Well-structured with bent/formed edges to increase bending stiffness
* Optimized winch position ensures correct winch line (synthetic rope) to the fairlead operating angle
* Integrated front collision release features to ensure proper function of chassis crumble zones
* Integrated design features to hold up the plate and winch for hand-free support. This No need for a hand jack, ropes or cable ties to hold up the plate during install.
* Easy to install without any cutting, drilling or use of specialized tools required
* Fits WARN ZEON series winches and most small-body winches without any cutting required
* Load rating: 12,000 pounds
* Durable satin black powder coat
* Mounts directly to the vehicle’s chassis frame. No cutting required. 100% bolt-on
* Added weight: 24 LBS
* Made in The United States
Note: We do not recommend installing WARN Power Plant winch due to its over sized body dimensions to fit in the JL Rubicon Steel Front Bumper. Superwinch EXP does not fit our current winch plate, we are working on a Gen2 plate that will accommodate the Superwinch EXP.
Install Video
PRODUCT OVERVIEW:
Install Video
