Maximus-3 JL Tow Loops (Front & Rear)
Status
Not open for further replies.
Baldeagle7007
Houston
2018 JL Rubicon
Need to flat-tow your JL? Searching for ultra-strong closed loop recovery points?
If you said yes, then say hello to the Maximus-3 Tow Loops available for the Front and Rear of your JL.
KEY FEATURES
* Made with 5/8" High-Strength Low Alloy Steel
* Laser Cut
* Keyed-in and Welded
* Designed to act as a SKID, protecting your bumpers
* Dual powder-coat finish (zinc rich primer + top coat)
* Two color options: RED Gloss -or- BLACK Textured
* Lifetime Structural Warranty
* Made in America
Maximus-3 FRONT Tow Loops:
* Rated for flat towing
* Pair with Maximus-3 blue-ox tow bar adapter lugs part# JK1009TA
* Excellent for recovery operations - closed loop for safety
* Fits standard 3/4 d-ring shackle, with 7/8" pin.
* Designed for the OE Rubicon steel bumper (requires cutting the bumper and skid plate)
* Works with the factory plastic bumper (requires cutting the bumper and air dam)
* MAY work with aftermarket bumpers (cutting & modifications likely)
Maximus-3 REAR Tow Loops:
* Incredibly strong recovery points
* More recovery options with dual closed loops v.s. factory
* Designed for the OE Steel Rear Bumper (no cutting required)
* Works with the factory plastic rear bumper (requires cutting the bumper)
* MAY work with aftermarket rear bumpers (cutting & other modifications may be necessary
From getting out of a sticky situation to getting across country, the Maximus-3 JL Tow Loops have you covered.
Can you show pictures of exactly what cuts need to be made on Rubicon OEM bumper and Skid plate.
I think these are exactly what I need.
Thanks, Jim Rice
James_a
Alameda, CA
2003 Rubicon, 2018 JLU Rubicon
Just to give you an idea of what's needed. This is for the D-ring loops not the Tow Loops but it should be similar. The cuts are not hard but I would recommend a cut-off wheel or angle grinder.
James_a
Alameda, CA
For the D-ring loops no modification was needed to the skid plate. For the Tow-loops no idea.
Jmonroe
Jay
2020 JLUR and a '99 Camaro SS convertible I bought new
Tow loops do require modifications to the skid plate, same as bumper. I used a 1.5" hole saw and an angle grinder.
Baldeagle7007
Houston
2018 JL Rubicon
James_a Thank you for all you info. Greatly appreciated.
I've spent hours looking for a replacement bumper and just really like the OEM Steel that's on it. This deifnitely gives me all my options of towbar use and still being able to add a winch.
Thanks again, Jim
TrickyO
Richard
Sydney
JLU Overland
Great reading all this. It looks like I may be able to install these. I have a JL Overland (Australian version of the Sahara). It has a tow loop on the underside of the bumper from the factory. No top tow hooks. It says nothing about it being useable for recovery. It is bolted flat on the front of the bumper mounting plate and seems to have reinforcing on the back of the plate, Only on the Drivers side.
Couple of questions:
1. Anyone tried a snatch strap recovery with the OEM loop? If so what happened?
2. If I install the Maximus-3 tow loops do I remove the extra reinforcing bracket to make it fit? You can see this clearly on the 3rd picture. These brackets are only on one side (ie the driver chasis rail).
Jmonroe
Jay
TrickyO, can't answer your question but I suspect those rings were designed as tiedown points for the boat ride to Australia. Are there a matching pair on the rear too?
Maximus-3
Maximus-3
BRENDAN
Detroit,MI
www.maximus-3.com
2020 Gladiator Rubicon, 2018 JLUR, 2015 JKU
Aftermarket Specialists
I recently installed the front tow loops (with winch plate), and figured I would share some pictures that show the cutting required.
These pictures show Maximus-3 JL TOW LOOPS, which WILL work with your winch plate.
We also make JL D-Ring Loops, they will only fit the Maximus-3 JL Winch Mount.
Jeep Wrangler JL Maximus-3 JL Tow Loops (Front & Rear) 20200605_121019
Hi Richard,
Yes the factory brackets (outside of chassis frame) get removed in order to install our tow loops. Our tow loops also reinforce that area with much thinker steel.
That is the first time we have seen that version of a factory "tow loop". We noticed the following:
* the material gets pretty thin near the bottom.
* we do not see much reinforcement - in our opinion, it's not ideal for recovery operations.
omg
Pennsylvania
2019 JLUR
Looks like the top bolt has no thread left.
Is that with washer installed?
are you using a winch plate also? maximus by any chance?
AnnDee4444
'18 JLR 2.0
I am using the Maximus-3 winch plate, with the two (inner?) spacer washers that are required. You are correct, there is no thread left on the top nut. I'm not too worried about it though... The winch plate added tons of strength between the frame rails, and the notch for the tow loops made the outer (removable) portions of the bumper weaker.
Jeep Wrangler JL Maximus-3 JL Tow Loops (Front & Rear) IMG_20200623_092119
  • Like
Reactions: omg
tatarin
Russ
Bloomingdale, IL
2019 MOAB Mojito Sky One-Touch, 2015 Lexus RX350F-sport, 2005 Camry SE
Will you guys run any 4th of july deals this year?
LooselyHeldPlans
Brandon
Denver
2020 3.6 JLUR
Several
We offer an everyday 5% JLWF member discount. To receive this discount you just need to call your order into us 248-821-6654.
ALSO, we are running a 4th of July sale, saving you 10%. Just head over to our website from July 4th - 7th and the discount will automatically be applied.
Cheers!
I placed an order on the 26th with the forum 5%. I haven't got a shipping confirmation or even an acknowledgement of my order... can I still qualify for the additional 5% off? I bought both the front and the rear.
Maximus-3
Maximus-3
BRENDAN
Detroit,MI
www.maximus-3.com
I placed an order on the 26th with the forum 5%. I haven't got a shipping confirmation or even an acknowledgement of my order... can I still qualify for the additional 5% off? I bout both the from and the rear.
Hi Brandon,
Your order shipped on 6/29 and is scheduled to be delivered today.
LooselyHeldPlans
Brandon
Denver
2020 3.6 JLUR
Several
Hi Brandon,
Yep, it was at my package center when I got home today. Will I qualify for the second 5% off?
LooselyHeldPlans
Brandon
Denver
2020 3.6 JLUR
Several
I installed my rear tow loops yesterday. I found a trick to the install that's maybe common knowledge, but it wasn't in the instructions and felt clever to me:
On the passenger rear, there's an included nutstrip that needs installed inside the frame. To get this in position, you need to remove the rear bumper. That's not a big deal, maybe 30 minutes of work in total. BUT... you can actually push the nutstrip through the oval hole a little bit forward on the frame. It is a super tight fit and I found inserting it in the frame hole with the "finger" upwards and then rotating the strip inside the frame did the trick. I then used a pair of pliers to hold the "finger" while I inserted the bolt.
Saves maybe 30 minutes or and 60 if you're like me and any install requires 2 or 3 on and offs before you get everything in the right order.
Overall, many thanks to Maximus-3 for this product. It allowed me to remove the flashy red factory hook, protect the rear bumper (since these can act somewhat as a slider), and increase the capabilities of the jeep wile keeping it close to stock.
Status
