Jmonroe
Jay
2020 JLUR and a '99 Camaro SS convertible I bought new
Well, I went to hook up the tow bar and found that the hole on the passenger side is a hair smaller than 7/8”, so the pin doesn’t fit. The pin fits fine in the other 3 holes. I sent an email off to Maximus about it we’ll see what they say.
I wonder uf the paint might be a little thick on the one side? I can't imagine the holes were made different sizes.
CarbonSteel
2019 Jeep Rubicon Unlimited
I am running front and rear loops on my Rubicon with steel front and rear bumpers. The only issue that I had was the passenger rear flag nut had to be ground a bit to allow it to slip into the hole in the frame without having to remove the rearbbumper. I removed the front bumper to install the front loops. Both sets are very nice and quite beefy.
Jgeiken
Jesse
Roscoe, IL
2018 JL Rubicon
That may be it, it’s a tiny amount. But I even tried to hammer the pin in and it didn’t work. I didn’t want the pin to get stuck or to chip the paint down to the metal.
Jmonroe
Jay
Maybe a Dremel with a small sanding disc
Redbaron73
Ronnie
2020 sport s unlimited;2020 Rubicon Unlimited
Hello, first post here. I’m wondering if anyone is running with any of the Roadmaster adapters for example the #rm035. I did read one person was using them without issue and another person saying there was an issue with the upward travel of the tow bar where the adapter was hitting the bottom of the bumper. I already have a Roadmaster tow bar and hoping to stick with it using the Maximus-3 Tow Loops.
thanks!
Bruce
I am running the road master. I am using nylon washers to remove the slack, and will upgrade to metal washers soon. Otherwise 8500 trouble free towing miles and going.
Bruceter
Bruce
British Columbia
2020 JLU Wrangler Rubicon,
Thanks for the reply,
so with the oem steel bumpers you have not any issues with the upward movement of the tow bar having the the tow bar adapters coming up against the bottom of the bumper using the Roadmaster tow bar and adapters? If you have had no problems this is the set up I’ll be going with.
thanks again
Bruce
Redbaron73
Ronnie
I use hitch stabilizers on all my hitch connections.
My rv required. 3 in drop so that was 1 extension. Then the Roadmaster 10k tow bar. Both of these have hitch stabilizers and my tow bar is .75" off level front to back. I have no movement or sway. Very stable.
My jeep has a 4 bike rack on the hitch, along with a hitch stabilizer there too. Very sturdy.
These are what I purchased.
https://www.amazon.com/dp/B07BPRDRJ9/ref=cm_sw_r_cp_apa_i_mCoJFbRWBCNY0
Bruceter
Bruce
British Columbia
Sorry but i think you maybe misunderstood what I was asking.
In this picture you can see where there might be a problem with the Roadmaster adapter, I was wondering if you found you had any issues here?
This is not my unit but just a picture I found on the interne.
Redbaron73
Ronnie
Oh, I see what you are asking. Mine does not look that close, and I have no rub marks on the skid plate.
Doug Huse
Doug
Lakeside, CA
2020 JLR, Fire Cracker Red, 2019 Winnie M/H, 2013 Kia Sorennto
Where does one look for an adapter-clevis to marry a tow loop to a Roadmaster tow bar?
Bruceter
Bruce
British Columbia
The Roadmaster #rm-035 adapters are the closest ones to working with the Maximus-3 Tow Loops. They are built to fasten to a 3/4” lug where the Maximus tow loops are only 5/8”. I think this isn’t a big problem with adding some shims t take up the gap. The other possible problem I’ve seen mentioned was in the upward travel of the tow bar the adapter comes up close to the bottom of the steel bumpers, doesn’t seem to be a problem on the plastic bumpers.
gandk
Greg
Oklahoma
www.instagram.com
2020 Jeep Wrangler Unlimited Rubicon
I am using the Maximus-3 tow loops with a Rugged Ridge Arcus winch bumper on my Gladiator. The Arcus provided bolts were not long enough to get through the added width of the beefy Maximus tow loops. No problem. I replaced all the Arcus bolts with longer grade 8 bolts. I have towed the Jeep on a few trips since installing. It tows better than the previous JK 2 dr, and the Maximus tow bar mounts have not budged. Happy customer.
Good job! I have that bumper and would like see if you could share additional side pics showing the loops below the bumper. Inwas wondering how far the loops extend below the Arcus bumper too.. I'm guessing you didn't have to cut the bumper and I see you got the fog lights installed also. Awesomeness!
Greg
TJDave
Eastern WA
2020 Gladiator Rubicon
Motorized toy collector
Greg
The factory led fog lights that came with the Rubicon's plastic bumper bolted right on. The factory steel skid worked too with a little grinding on the mounts. I did have to cut the Arcus bumper's outer cover a little. No big deal. This is the only picture that I have on my computer at the moment.
gandk
Greg
Oklahoma
www.instagram.com
Looks great! I want it now. But need the blue ox tow bar adapters...
Mac Haik CDJR Georgetown
