Maximus-3
Peak Sponsor (Level 2)
Tyler
Detroit,MI
www.maximus-3.com
2020 Gladiator Rubicon, 2018 JLUR, 2015 JKU
Aftermarket Specialists
The wait is over, the champ is here.
Our Maximus-3 JL Tire Carrier began with world-class engineering and precision U.S. manufacturing. Then nearly two years of research, development, and extensive field-testing. Resulting in a far superior product. No other company has put this much effort into their carriers – and it shows.
More than just a tire carrier.
The Maximus-3 JL Tire Carrier is the ultimate modular carrying solution. Not only can it carry a massive tire but also a wide variety of off-road and overland accessories.
The Maximus-3 JL Tire Carrier is the strongest, smoothest, and most modular spare-tire holder on the market. 100% bolt-on application. The body-mounted tubular design provides a strong, rattle free, and fluid swing operation. Highly adjustable to fit different wheel and tire combinations. Effortless one-handed cycling motion.
For extreme strength we offer an internal body-tub reinforcement brace to provide better load distribution for the factory mounting points. Rated to hold a 40” tire plus accessories.
Load-up your Maximus-3 JL Tire Carrier with a wide variety of optional mounting brackets for: Hi-Lift Jack, Shovel, RotopaX, NATO Cans, LED Work Light, Reverse Light, CB Antenna, Trail Flag, and more. Dozens of off-road and overland accessory combinations.
· Designed specifically for the 2018-current JL/JLU Wrangler
· 100% bolt-on installation. No cutting, drilling, or modifications
· Versatile design to allow for different loading requirements and configurations
· Made of a unique one-piece design heavy gauge steel tubular construction – 2” OD tube
· Articulating hinged design for synchronized opening and closing of the tailgate
· Integrated pre-tension mechanism for rattle/vibration-free running.
· Wide hinge bearing points for better stability and load distribution
· Effortless door opening due to low friction self-lubricating bronze bearings
· Holds 40” tires
· Height Adjustment for low center of weight and best field of view.
· Adjustable tire mount for different tire/wheel combinations.
· Minimalist robust design with built-in quality control features
· Durable fine textured black powder coat finish
· Hinge design is completely independent of the factory door hinge.
· Spare Tire rubber contacts the tube at multiple points for stability and even load distribution
· Various optional accessories and mounts available
· Made in The United States
Andy2434
Andy
Las Vegas/San Francisco
'19 Billet JLUR, '20 Mustang GT, 6MT
Retired/Leisure
Where and how to place an order? Cannot find it on your site, currently.
SnowDog
Paul
Denver
SSinGA
Sean
Alabama
2018 JLUR, 2016 JKRHR, 2012 JKU Sahara
Just up and down adjustment or also fwd and aft? Need to be able to accommodate a 37x13.50 on a 4.5bs 17x9 wheel.
Jason
Jason
KC
2018 JLUR StingGray
So does the sport package come with what you need to install the rotopax mounts? Or is that separate? Didn’t see any separate mounts on the site
luna4x4
Ryan
Southern California
2018 JLUS
Do you have a link to the installation instructions on your website? I like to go through the instructions before purchasing a product just to see what is involved.
intentsrig
JLU Sporticon
Link to the instructions would be useful. definitely want to see that before purchasing.
Also, support bracket needed for 37’s as well? Why is that, just wondering since no one else does. Hell, I I have been running a 37 on the stock carrier for over a year.
johndplm
Northern, NJ
2019 Jeep Wrangler
Yes please provide a video installation and paper instructions please. Soon would be great as Id like to purchase one ASAP if I like what I see in the install and hardware...
cosmokenney
Cosmo
Auburn, CA
2019 JL Wrangler
Great design! I never liked the bumper carriers. I'll probably get one of these next tax refund.
Andy2434
Andy
Retired/Leisure
As others have noted, prior to purchasing, I would also like to view the installation instructions.
Hydroboy35th
Josh
Zanesfield Ohio
2018 JLR
To all you guys wanting to see installation videos get on YouTube and watch one from motobilt or evo. The principal will be the same, remove interior panels, remove hinges, run some wiring, bolt new stuff up etc. etc. Have a helper with removing the tailgate. It shouldn’t be too bad at least this one doesn’t look like it weights 80lbs haha.
JDub11
Illinois
2020 jl 2012jk
If you look at the pics it clearly adjust in and out
PSC Motorsports
