terjon
Johnny
Abu Dhabi
Jeep JL sport s
What is the sizes of the long and short platforms?
American Jeeper
Jeremy
Kansas
2019 JLUR
Software & cloud services
I could be wrong, but here's what I (think I) am seeing:
As best I can tell, the current pioneer platform leading cross member is slightly rounded on top with a flat leading edge.
The one shown in the SEMA photos tapers a bit and the leading edge is angled back, which I assume helps reduce wind noise from the rack.
https://www.jlwranglerforums.com/forum/attachments/rhino-rack-jl-wrangler-sema-2018-3-jpg.104671/
I could be totally wrong about all of this and maybe it's just the camera angle playing tricks on me. I thought it was mentioned in the Rhinorack SEMA thread but I read through the thread again and couldn't find it so perhaps I dreamed the whole thing.
Looks like that is the new model that hasn’t been released yet by Rhino.
brain
brian
Milton, Georgia
www.unsinkablebriancork.com
2020 Wrangler JT (Gladiator) Mojave | Gobi
Business and Executive Coach
Would be nice if the 2-door rack is compatible with removing the freedom panels. And/Or maybe opening the Sunrider for Hardtop. Just a little input from a likely end-user.
Yes please to the 2DR effort.
alkapin
Alex
Vancouver, BC
2018 White JLUR, 2014 White GL350
Hi @maxumus-3 I have just finished installing the long version of the platform with an optional ladder on my 2018 JLUR. Looks great! Now, do you have any experience or recommendations for installation of the ikamper skycamp RTT? I don't want the platform railings to minimize the height, so the bottom of the RTT will sit directly on the platform. But normal install of this RTT required a roof cargo railing that runs perpendicular to the vehicle length, but the platform slats run parallel to the length. So it is not very obvious how to mount Skycamp. Looks like that mounting brackets needs to be refabricated to rotate 90 degrees. Anyone has done it before with this combo? I have attached Skycamp mounting details pdf.
Maximus-3
Maximus-3
Peak Sponsor (Level 2)
Tyler
Detroit,MI
www.maximus-3.com
2020 Gladiator Rubicon, 2018 JLUR, 2015 JKU
Aftermarket Specialists
  • Thread starter
  • Thread Starter
  • #68
Hi @alkapin
There are several custom mounting solutions that come to mind. Let's go over them to figure out what works best for you.
Option 1: Rotating your your mounting brackets 90* sounds like a viable solution, depending on the amount of custom work required.
Option 2: Try to use the plank's channels to mount your tent. Similar to our Maximus-3 custom RTT mounting solution (see attached install guide.) You can slip channel-nuts into the planks and then bolt your tent directly to the platform.
Option 3: Install some crossbars from Rhino Rack on top of your platform. The crossbars run perpendicular to the length of the Jeep. This option does add about an inch of height
Option 4: In between the 5 planks on the platform you can access the underneath crossbars. If the space between the planks matches your tent's mounting dimensions you could run a bracket or u-bolt under the crossbars on the underside of the platform.
I'm sure there are other ways to "skin this cat." Hope this is helpful.
Maximus-3
Maximus-3
Maximus-3
Tyler
Detroit,MI
www.maximus-3.com
  • Thread starter
  • Thread Starter
  • #69
Hot off the press. The Maximus-3 JL Roof Rack SHORT platform is fully compatible with the Bestop Sunrider for Hardtop for JL.
Confirmed by Dr. David N. Thanks for blazing that trail with your sweet Mojito JLUR.
High capacity Maximus-3 roof rack + easy open air from @BestopTeam = an iconic duo.
American Jeeper
Jeremy
Kansas
2019 JLUR
Well done!
anotheraznguy
Tracy California
Mojito JLUR
That is what i was waiting for. Did you have to drill new holes? or is maximus 3 able to drill them for us before they ship out?
JeepGA
North Georgia
2018 Jeep Wrangler JLUR
Hi @alkapin
Maximus-3
This is also the RTT I'm thinking about. Let me know if anyone gets this installed.
Maximus-3
Maximus-3
Tyler
Detroit,MI
www.maximus-3.com
  • Thread starter
  • Thread Starter
  • #73
This combo does not require any additional holes, nor custom mounting. Just install the Short Roof Rack per the normal instructions and you are good to go.
Maximus-3
Maximus-3
Tyler
Detroit,MI
www.maximus-3.com
  • Thread starter
  • Thread Starter
  • #74
Maximus-3 provides an excellent platform for holding RTT's with a 900+ pound static load rating. There are dozens of tents on the market, sometimes it takes a little custom mounting to fit certain tents to our Rack. But where there is a will there is a way. I'm sure it's doable by choosing one of the options we mentioned.
Natelee
Nate
Atlanta
2018 JLUR, 2018 Ford Raptor
I know this is the roof rack thread but is there a best guess on the tire carrier ETA you referenced earlier? Thanks! @Maximus-3
Superchips Flashcal Programmer out for JL Wrangler
