eman20
eman20 Here are a few pics I could find that kind of show the mounts. The Frontrunner mounts hold the RTT 2.5" above the rack. This allows the skirt of the RTT to perfectly hide the mounts and the gap when deployed.
Thanks DeekT I appreciate the photos. Looks great. 2.5” is not bad from platform to bottom of tent. I thought it would be higher. I guess your quick clips is on the 2 outside pioneer platform c-chanels then so you can reach it ? You have a channel on the frame and then just in from the frame is the first c-chanel, that’s the one I’m referring to.
DeekT
Deek
Illinois
2018 Punk'n JLU Rubicon (mine), 2018 White JLU Moab (wife)
That is correct. Also, once I aligned everything where I wanted it the first time I put a paint mark on the platform at each bracket front and back. I always take the lower bracket mounts off the platform when the RTT is not on and this allows quick reinstallation in the exact location. When the RTT is on you can easily reach the bracket hold-down bolts in case you wanted to move it a little farther forward or back for weight distribution or attaching something else.
eman20
DeekT Sorry to bother you again but I’m thinking your idea is the way to go and I’m about to purchase the quick real ease kit from front runner specifically for ikamper. Wanted to check back in now that you have had some time to use this system.
- Do you feel still good with this setup ?
- Any rattling or shifting from the brackets when on trails ?
- Any other negatives or positives you can add before I start drilling into my hard shell ikamper which wasn’t cheap :).
- does having the quick release brackets so close to the outside rack chanel cause any weight distribution issues ?
One more thing. Could you share the bolt size you used for the ikamper base to quick release bracket and any washers nuts you used ? Hoping it didn’t protrude Inside the tent too much that it sticks into mattress.
Thanks again for your info on all this much appreciated. Hope it’s treating you well.
DeekT
Deek
Illinois
Yes, definitely a good setup IMO.
No rattling or shifting, at least none that I noticed.
Only negatives for me were the latches on two of the frontrunner brackets ended up close to the mounting location for the RTT straps, but this should not be a problem for you with a hard shell, and there are two of the latches that require a security torx key to open that is very tight access with the provided key. I solved this by purchasing a T-handle security torx wrench that is like 6" or 8" long. Think I got it off Amazon for a couple $ for a whole set of different sizes.
No weight distribution issues at all. My RTT is a CVT Mt. Rainier which is their second largest (size of a California king bed when open).
As far as hardware, my setup is a little different from you (I believe). My RTT base is honeycomb between aluminum diamond-plate. It's quite thick and I had to be careful not to crush it. I have the latch bracket on the bottom side and one of the provided channel nut plates on the inside. You should be able to simply use the hardware provided. I use a shipping blanket under the mattress to make sure there is no snagging on the channel nut plates. For mounting the mount brackets to the pioneer platform I got some channel nuts (see pic) which allows front to back adjustments. You can get these in standard or metric thread sizes. I used a 5/16" x 3/4" long bolt with locking washer and flat washer.
That's it. Hope this helps.
eman20
This is very helpfully and thank you for taking the time to write up some of these details.
My fear apart from screwing up where I’m drilling holes 😜 is having the brackets so close to the edge might affect the weight in the middle if it’s up slightly off the platform. I always felt that’s why ikamper put their rails where they put them closer to center and out, for that distribution of weight when inside the tent and moving around.
I can see it not been a problem when driving as in weight distribution but more so when inside the tenth and not having that center support. So it’s good to hear that didn’t affect your setup and your tent been bigger area mass than mine so thanks for that.
I think your approach is the way to go for me too. Now getting around it it.
Slickrickmotoadv
Rick
Santa Rosa, CA
2019 Wrangler Unlimited Sahara, 2017 Miata Club RF
Just read all 20 pages. I just got my 2019 Sahara and had pretty much decided on this rack with the iKamper hardshell. Really happy I found all this info. Thanks @eman20 and @DeekT big time! Looks like I'll be going the Maximus-3 long rack, FR quick release mounts, and the iKamper itself route. I'll post pics when it's done.
eman20
Congrats, please do post your setup details when you finish. I got caught up with work and haven’t had to chance to order my FR mounts yet, but still instead to go this route with my hard shell.
nU7OuxIx
Chicago
2021 JLU Rubicon, YJ, Impreza
I have three questions about this system. I think I know the answers for them but I just wanted to ask and verify.
Is it available with just the cross-bars and not the pioneer rack system?
Can you remove it all-together, and just be left with some little pads, similar to how the rhino rack is?
What is the off-road weight limit?
Thank You!
LeoTheDragon
In my Jeep
2019 JLUR
Sorry if this has been asked before, but can you give me the dimensions of the back rail kit? Mainly interested in the height and how far up the side of the platform it goes. Thanks!
jeepinalaska
Alaska, USA
2019 Jeep Wrangler Sahara Unlimited
I have the larger size maxims 3 rack system on my 2019 JLU. Since summer is fast approaching I will no doubt want to take my hard top off, however the one time I did this last summer, I ran into issues with the roof rack system. The forward bolts are extremely difficult to access from the underside, and as such it is very difficult to take the top off with the rack securely connected (The workaround I found involved unscrewing it from the top outside, which was complicated and made it flimsy). Has anyone else ran into this, and what tool do you use that can get in there to easily unscrew it from the inside?
eman20
Thank You!
I have the system on a 2 door and I love the low profile look and it’s a solid build and quality product.
if your looking to remove the rack then this is not the system for you. I didn’t have the option of a rhino rack with the 2 door but if I did I would have leaned towards it as it looks easier to remove.
in saying that I love the Maximus but just can’t remove it unless I want a headache for the day.
not sure if you can get it with just the crossbars, but Maximus are very helpful when you call. I got my brackets without the platform as I already had one and when I called Maximus the were very helpfully in just selling me the brackets.
Bestop
