Bluebear
I installed the rack and later cut my headliners to go around the brackets. Using a razor blade it wasn't too difficult. I believe my rough measurements were 8cm from the outside of each headliner. I then cut out to 7.5cm from the outside for room of the actual bracket. I didn't see any instructions with the kit so I just figured it out.Any one know if it is necessary to remove the soft panel / insulation that is stuck to the inside of the roof in order to install the Maximus-3?
Measuring many times and a pencil to mark on the back side of the headliner is your friend.
