35 will rub quiet a lot in moderate trails also from what I read...i believe someone tried it33's fit fine. 35's fit with little rubbing at full turn. 37's fit with lots of rubbing. search and you'll see a couple sports with 37's here that are tightttt waiting on a lift for sure.
lol def on trails. yikes lol35 will rub quiet a lot in moderate trails also from what I read...i believe someone tried it
looking at same size nitto - other threads say a resounding yes, but not for any real offroad use without potential rubbingDid not want to start a new thread... so here you go.
Need your suggestion fellow Jeepers.. I am looking to upgrade the tires on my JlU sport keeping the OEM wheels, will these tires be fine on them - BFG LT285/75R17 / E 121S.
Thanks a ton!
I have a lift with those tires and Rubicon wheels no rubbing anywhere you will need a spare tire relocating bracket at least I did on my sport interefered with bumper.looking at same size nitto - other threads say a resounding yes, but not for any real offroad use without potential rubbing
they’re actually about 34, not 33, so plan is to get the teraflex leveling kit when it’s ready - under 200 bucks and bumps front up 2 inches, rear 1 inch and that should be more than enough
other concern is euro cover on sport bumper - i plan to get a new front bumper so should address that rubbing spot if it happens...now need to figure out if wheels should also get small spacers too to handle tight turns and avoid any rubs
the rubicon wheel on sport rim interfered with bumper?I have a lift with those tires and Rubicon wheels no rubbing anywhere you will need a spare tire relocating bracket at least I did on my sport interefered with bumper.
The Rubicon wheel with a 285/75/17 Nitto ridge grappler did - I don’t think I have seen issues with Rubicon take offs on sports.the rubicon wheel on sport rim interfered with bumper?
That's kind of a loaded question. It all depends on what you're planning to do with it. If all you're planning on doing is pounding pavement you could probably squeeze a skinny 33 or 35 under it with maybe minor rubbing the larger you go.Good Afternoon everyone,
I'm sure this might have been asked and answered but looking to see if any knows the max tire size you can install on a stock base JLU sport without installing any lift?
Cheers
could I fit 315/70/17 on my stock 2018 JLU Sport S, or would wheel spacers do the trick? or do I actually need a 2'' lift??
