Max Terrain Fender Flare Set, F & R; 18-20 JL/JLU
lsp408
Li
Knoxville TN
2017 JKUS
Question, on the LED wiring, the instruction gives you 3 choices
one with factory LED
One without LED
One with LED without switchback
what is the LED without switchback? I got factory LED package and assumed just to follow option 1?
Gear_AU
Jeffrey
Australia
Jeep Wrangler Rubicon
Just installed a set of these. Anyone have problems getting a close fit. One side is ok, the other has a gap.
steffen707
Wisconsin
2020 Gladiator Sport S (Gladys) - 89' Civic SI
Im running Revolution 4.88 with factory diffs. FYI, my gas mileage is garbage, getting 12 mpg FML!
well my stock JT is getting 14.5-15, so 12 isn't TOO bad. Wonder what a 392 JT running 4.88 would get mpg.....who cares I guess.
CptFloridaMan
Gabriel
Miami
2018 JLU Sport 2.0
One without LED
Based on this, if I were to wire it as a LED package JL, and flash with my JSCAN, it should in theory work like the oem DRLs? I want to figure a way for the DRL to work without messing with the headlight switch.
lsp408
Li
Knoxville TN
2017 JKUS
make sense to me. But mine came factory with LED package. So I did not have to go through what you mentioned here
lsp408
Li
Knoxville TN
2017 JKUS
I noticed a little gap on mine too. I have some double sided tape and adhesive promoter. May make couple brackets and taped to inside of fender and secure onto those two holes Max terrain fender flare not used
CptFloridaMan
Gabriel
Miami
2018 JLU Sport 2.0
Guess we’re about to find out when I buy it next month. I’ll update whenever I install.
CptFloridaMan
Gabriel
Miami
2018 JLU Sport 2.0
Just got my set in, one of the flares came damaged, quadratec is sending another set so I can just replace the broken one. I was also missing one of the stanchions for the front. Does anyone know where I can find replacements from rugged ridge?
Superchips Flashcal Programmer out for JL Wrangler
