Undisclosed Manual Transmission Shifter Knob Replacement
New Orleans
2019 JLU Rubicon
Any ideas on replacing the manual transmission shifter knob. I like the pull lever style but can't find replacement as "chrome" is peeling off?
Kenny
Ken
Utah
2018 jl sports, 2015 JK Unlimited, 2013 JK @ Dr
Village Idiot
B&M has a nice shifter
Sting_NC_USA
Michael
Greensboro, NC
+1 on the B&M. That's where my money will eventually go.
daveprice7
Junction City, OR
2019 Sport 2DR, 2020 Willys 2DR
Nerd
didyou or anyone install these? The B&M install seems a little bit much for me
I haven't, no, but it's just a knob replacement. The knob adapter will either be a press fit or a set screw I'm sure.. the knob itself threads onto the adapter that's part of the setup they sell.
The toughest part will likely just be removing your current knob, which I have done. I wrapped some rope under it, then tied it to a block of wood .. I let the rope go a little slack and then gave it a quick lift up and the knob came right off... Much easier than trying to tap it out IMO (though I used too much force and nearly went through the soft top.. so be careful!). I haven't tried the transfer case knob, it might come off differently, not sure.
aklino
Andrew
Livermore, CA
2018 JL Wrangler Unlimited Sport
I recently installed the B&M on mine. Piece of cake. It really isn't difficult. Hardest part is removing the factory knob, which if you do it right, is pretty easy. Take a short length of 2x4 (12-18" long or so), and wedge it up under the knob. Hit the wood block with a positive persuasion device (aka "a hammer"), and it should fly off on the first whack. The rest of the install should take you no more than maybe 20 minutes. It's really simple.
If it makes you more comfortable, PM me -- I'll give you my phone #, and I can walk you thru it.
