Maverick909
- Brian
- Jan 15, 2019
- Inland Empire
- Website
- www.instagram.com
- 2018 JLU Sporticon, 1976 GMC K15, 67 Notchback Barracuda
- Build Thread
- Link
- Occupation
- Electrician/ Industrial Furnace MFG
If you’re driving flat surface roads with no hills and an automatic you can get away with 4.10 gears on 37’s I’ve had a lot of experience with 3.45, 4.10, and 4.88 with tire size ranging from the sports stock 31’s to 37’s. I still run 17+ mpg with 4.88 and 37’s on my Jeep. 4.10’s can’t climb a hill on the highway with 37’s without sitting at the 4500+ rpm range the whole time. If you like tuning your truck that way that’s fine but I can run 70-80mph on most the grades in California at 2500-2800 rpm with out the need to down shift with my 4.88’s. For Off-road hill climbing with a rubicon x-case 4:1 you can get away with it but itnwillMy experience is in my Rubicon with 4.10 gears, if you have a Sport/Sahara with 3.45s then it isn't going to behave the same. In fact I know it sucks which is just one reason I didn't take delivery of my 24 Sport after I test drove it. I knew right off the bat I wasn't going to be happy with those 3.45 gears. They were "fine" for stock tires but I also knew I was going to 35s and they weren't going to cut it. I've had a truck with 4.10 gears on 35s in the past and know from experience that it works for me. In fact that truck didn't have a 5.13 first gear or 4:1 low range transfer case so the Rubicon should perform a lot better on 35 inch tires than that truck ever did. In fact I think the 4.10s are fine up to a 37 inch tire.
And I know for a fact there are people on this forum that think what I just said is blasphemy of the highest order and will tell you all day that you need 4.88s or lower for 37+ inch tires. Whatever.
Just because, I double checked...on 37s at 80mph with 4.10 gears you still turn more rpm than you do in a stock Sport at 80 mph.
Feel closer to the sports 2.72:1 with 4.10 gear ratio. But when I wheel or am driving to wheel I spent my time in the higher elevation’s with long grades to get to where I wanna go wheeling.
as for the OP. Gear ratio depends on what you do with YOUR jeep. Daily driving it just a weekend warrior off roader. Etc. and what time if areas you drive the most at. If you’re looking for more pep then up the gears. But you will sacrifice a little mpg.
