Manual Transmission Cruise Control Surprise
AVGeek99
AVGeek99
Delano, MN
2021 JLUR, 2021 Sahara 4xe (wife's)
I don't have adaptive cruise. That might cause your Jeep to behave differently by design. Still, I doubt it. Not cutting throttle when you push in the clutch pedal sounds like a dangerous malfunction to me. I'd get it checked out.
It is definitely by design and works really well. As soon as you push in the clutch or pull it out of gear the engine RPMs drop just as you would expect. I didn't notice any sort of RPM spike at all, not even for a split second. As soon as you put it in gear it resumes. It will disengage if you leave it in neutral for 5-6 seconds.
omnitonic
Michael
Southwest Virginia
2021 JLU Willys in Sarge Green
truck driver
I had to go back and read the original post again. So it drops the RPMs when the clutch pedal is down, and then picks right back up. Okay, that's different! I've had vehicles malfunction such that when you push in the clutch, the engine just red lines until you kill the cruise. That's what I thought you were saying, but I colored my reading of your post with my past experience, instead of actually comprehending your message.
It happens. 😜
Tazer JL - Z Automotive
