Major issue with 4xe lifts... Teraflex and others on 4xe
moments.by.ron
Ron
Macedonia, Ohio
2021 JLU Sahara 4xe
Keep in mind that the 1" more lift of the 4xe is only applicable to spacer lifts. Lifts that swap springs won't have this issue as you're swapping out the part that causes the 1" lift. That said, spring lifts not designed for the 4xe probably will be (read as "will definitely be") not the same result as a non-4xe.
eLECTRICON
Shane
PA
www.facebook.com
2021 Rubicon 4xe
Law Enforcement
Let me preface by saying I called Teraflex before purchasing their ST1-1 spacer lift and was given the green light to install on my 4xe
Seems since the 4xe is lifted about 1" higher than non 4xe (at least the Rubicon) even a small 1.5" spacer lift requires longer Swaybar links. Here is the back story. I installed the Teraflex ST1 1.5" lift (2" front and 1.5" rear) then ordered the Fox 2.0 shocks for 2" lift extended shocks (as recommended by Northridge). When installing the rear shocks I discovered that when I jacked up the rear to align and get the shock in the lower sleeve I noticed the Swaybar preventing the shock from swinging into the sleeve. So I had to lower the Wrangler down and then muscle the shock in. However if say I need to change the tire or even likely go to full articulation the sway bar will rest on the shock body well before the tire leaves the ground. This is a major problem as the weight on the sway bar could dent the shock body in extreme conditions or even changing a rear tire. Clearly with the added 1" stock lift addition on the 4XE makes that 1.5" lift a 2.5: lift (3" front and 2.5" rear) which does require longer sway bar links on a non 4xe. Here is how I found this out and is easy not to see.
This could easily be over looked as Shocks come compressed with a strap around them you want to try and install the shocks with that strap in place otherwise the shock will extend and it is a bitch to get it compressed enough to fit. So I had one shock where the strap came off prior to installation so I jacked the Wrangler up extra high to extend the distance to help get that shock in the sleeve. but it would not fit because the sway bar was resting against holding the shock about 2" away from the sleeve. Bottom line order (2-2,5" longer) new swaybar links for any lift 1" or more on the 4xe.
The Sway bar should only be at a 10-15 degree angle mine is about 27 degrees in this picture this is with full weight on it
I just spoke to Teraflex they are now saying they do not endorse their lifts on the 4xe and probably will not for a couple months. I called them to discuss this problem as well as find out status of longer sway bar links for which they have NO idea when they will have any for sale (they are on indefinite backorder it appears). Frustrating as I called Teraflex prior to installing my lift and they said no problem will work just fine. Now they are saying that the 4xe is a whole different animal and is going to require quite some time in R&D before they have a lift spacer or spring for the 4xe. With that said this is an easy fix just add longer sway bar links, problem with that all the manufactures are out of them with No supply in sight... I Suggested that Teraflex put a warning on their kit regarding this issue with the 4xe but they did not seem to interested in that. So this is my WARNING.
problem now is I lift installed and cannot go off road, cannot even change a tire without removing shocks first.
These will work for you.
https://www.quadratec.com/p/mopar/front-sway-bar-end-link-wrangler-jl-mopar-lift-68306982AA
https://www.quadratec.com/p/mopar/front-sway-bar-end-link-wrangler-jl-mopar-lift-68306981AA
or return the 1.5 and get this instead.
https://www.quadratec.com/p/teraflex/2-5-inch-performance-spacer-lift-kit-jeep-wrangler-unlimited-jl
seannaz
Sean
Scottsdale AZ
2021 Wrangler JKUR 4XE, Cyber Truck (on order...)
I have a Teraflex 3.5" lift. No issues at all. Did hells gate/revenge in Moab in all electric mode.
Ohhh - tell us about your all electric experience out in Moab!!!
lightsout
lightsout
Gary
Seattle
  • Thread starter
  • Thread Starter
  • #35
Thanks however I already ordered those links last week they were back ordered then. I would and go to 37's except we will pulling behind a Diesel pusher trying to keep the weight down pushing 6000lbs as it is.
Stinger Off-Road
