Magnuson Supercharger available $6495
LateBraking
Y'all a cult.
Illuminati Headquarters
2018 Jeep Wrangler JL Rubicon
I just want to hear the supercharger noise.
I'm a child inside, I know. :) Noise videos please.
rickinAZ
Rick
Phoenix
2021 Rubicon EcoDiesel (11th Jeep)
It hasn't been mentioned before, so I will: Don't do it.
I don't believe that there has been a single hassle-free turbo/supercharger installation reported in the JK forums. Everyone goes into it full bore, and then sheepishly return with tales of woe.
And...I'm a forced induction fan; just not on a Wrangler. [except for the turbo-diesel that I'm ordering when the 2021 order banks open]
The Custom Jeep Builder
Todd
Scottsdale, AZ
2020 Gladiator, 2021 392 Rubicon
Jeep Customizer
We have had countless positive experiences with Forced induction here at Doetsch Offroad, including my own personal 3.6 that ran a RIPP unit on it. GOOD Tuner & good gas is a must
Hydroboy35th
Josh
Zanesfield Ohio
2018 JLR
I really don’t think the engine/drivetrain can handle the power this puts out. Do we have any testing results other than a couple dyno runs? Any long term testing results would be nice.
Todd
Scottsdale, AZ
Jeep Customizer
I ran 7, 8.5 and 10 PSI through my identical 3.6 Pentastar in my 2016 Grand Cherokee. At peak, I made 417awhp & 396tq.
I put 30k miles on that SC with no major issues to speak of until the new owner blew it up on garbage gas, climbing the AZ mountains in the summer. He has since rebuilt, lower comp and runs 12psi on pump gas reliably.
alphalife9
Rio Rancho, NM
Z51 C6, Sting Gray JLUR
I ran 7, 8.5 and 10 PSI through my identical 3.6 Pentastar in my 2015 Grand Cherokee. At peak, I made 417awhp & 396tq.
I'd run the smallest pulley and vent at 7PSI to build boost as fast as possible and leave headroom for safety..just want the low end torque. I'm looking forward to seeing some feedback on real world usage traveling through changing altitudes and octane availability.
beaups
Sean
Ohio
2020 JL
Your 10.2:1 compression GC 3.6 is identical to the 11.3:1 compression ratio JL 3.6?
AZDustMuncher
L.C.
Arizona
2018 4dr Rubicon, 2005 Turbo Silverado, 2004 Grand Cherokee Overland
PD superchargers build boost down low, doesn't make any sense.
alphalife9
Rio Rancho, NM
It does make sense, I want peak PSI at the lowest RPMs as possible. Since superchargers run off the crank speed, reaching the peak PSI very early on mens the supercharger will surpass that peak with increased engine speed. Like you mentioned, these build up quickly at low RPMs and that's what i want to maximize.
AZDustMuncher
L.C.
Arizona
The moment the bypass valve closes you have boost on a tvs. Even if you made it work you'd probably lose hp spinning the supercharger faster then it needs tho be spun and have more problems with the belt.
alphalife9
Rio Rancho, NM
I know, I'm not worried about losing HP, just want gobs of torque under the curve starting real early. A heavy-duty belt setup would take care of reliability. It would be a small price to pay for a significant increase in torque where it matters most and cheaper than a V8 swap.
