Philip
- Philip
- Aug 31, 2020
- Aurora, Co
- 2021 JLUR 392 x2
- Occupation
- IT Strategy Consultant
Sunday, 8/30
Empire/Dumont Loop
• Started in Empire and made it up to Bill Moore Lake
• Began decent and turned off for the creek trail.
○ Shortly after crossing the first (small) creek, the jeep stalled on the trail. After restarting:
§ the Check engine light came on
§ the battery began losing voltage (~13.5… 12, 11, 10, 9…)
§ Every warning light eventually turned on… and throttle became very jerky and eventually unresponsive.
□ @ ~9.3 volts, I stopped on the trail, connected my portable battery to the (running) jeep, and turned on the portable battery. The stopping point was ~ 1/2 way between the 2 creek crossings.
® Voltage would go up but would immediately drop if I turned off the portable battery… so I decided to turn off the jeep as well as the portable battery because I was concerned I would eventually drain my portable battery pack and be stranded. (took a picture of the dash)
® Engine temp was fine and external temp was 61 degrees and it started to rain
◊ Waited about 20 to 30 minutes and decided to jumpstart the engine.
} Jumpstart worked and the battery voltage (dash readout) returned to over 13v… but all the warning lights remained on… Having no other options, I decided to continue through the trail and exit, via Red Elephant/Dumont, Co.
– The battery maintained the charge and appeared to be working after it was jumpstarted… though the check engine light and warning lights remained on.
w Drove home and made the next available appointment at the dealership…
w Also called @JeepCares to open a report (case# 77095216)
Empire/Dumont Loop
