StrikeZ
I banged my ROAMs off of some rock and slid off some trees. They seemed to hold up well. They even greatly reduced the mud spray off the front tires.
For the money, I'd recommend the e-coated frame mounted ones. I know they have those in stock and they are absolutely awesome.I emailed Anthony @ROAM 2 weeks ago asking about availability of body mounted side steps and never got a response. I really like em but damn the communication is less than stellar.
I hear ya but now I'm just wary of the customer service in general.
If I dont hear back from them about the body mount version I'll just wait for the west coast ones.For the money, I'd recommend the e-coated frame mounted ones. I know they have those in stock and they are absolutely awesome.
Brett
Great info. The ROAM logo doesn’t show in your profile pix, did you do anything to hide/mask it?For those thinking of wiring up the lights but are worried about a complex setup with relay etc. I hooked both sides together and ran the positive wire up on the passenger side, and then tapped directly into the entry wire lead of the LED that is mounted in the passenger footwell. I was a little worried about overloading the circuit but I have not had any issues in the 2 or 3 months these have been installed.
Did you ground the negative to the body? Mind sharing what you did with the negative as well?For those thinking of wiring up the lights but are worried about a complex setup with relay etc. I hooked both sides together and ran the positive wire up on the passenger side, and then tapped directly into the entry wire lead of the LED that is mounted in the passenger footwell. I was a little worried about overloading the circuit but I have not had any issues in the 2 or 3 months these have been installed.
Yes, I grounded the negatives to the frame.Did you ground the negative to the body? Mind sharing what you did with the negative as well?
It is still there. I just inserted the black block off plates that were included. You can still see them if you are close or zoom into the photo but it is not as obvious.Great info. The ROAM logo doesn’t show in your profile pix, did you do anything to hide/mask it?
Looks great with the lift and tiresIt is still there. I just inserted the black block off plates that were included. You can still see them if you are close or zoom into the photo but it is not as obvious.
Any pics of which wires you tapped and the ground. Looking to do this also. ThanksFor those thinking of wiring up the lights but are worried about a complex setup with relay etc. I hooked both sides together and ran the positive wire up on the passenger side, and then tapped directly into the entry wire lead of the LED that is mounted in the passenger footwell. I was a little worried about overloading the circuit but I have not had any issues in the 2 or 3 months these have been installed.
I did the same. Routed the driver side led wires up into the engine compartment and thru a cap high up under the driver side dash. The hole is where the clutch goes if it were a manual. I then tapped into the wires going to the under dash convenience light.Did you ground the negative to the body? Mind sharing what you did with the negative as well?
