Love my Rubicon 4xe, but this drives me crazy!
DanN427
Long Island, NY
2021 Firecracker Red Wrangler Rubicon 4Xe
I absolutely LOVE my Jeep. I waited a long time to get one and couldn't be happier!
But there's one small, tiny, insignificant thing that drives me nuts:
Why on earth does the menu in the center of the instrument cluster page up when you push the down arrow and page down when you push the up arrow on the left of the steering wheel??
It's so counter-intuitive! If I am on page 3, then hit the up arrow, I would expect to be on page 4.
Again, so insignificant, but it drives my OCD crazy!!
Thanks for listening!! ;)
jludave
The Isle of Long
IT Manager
Up = Previous
Down = Next
It's like using a trackwheel on a computer mouse. Typically, you scroll up and whatever you are looking at scrolls down and vice versa.
Maverick909
Inland Empire
www.instagram.com
It matches the ass backwards automatic transmission shifter: up to downshift; down to upshift...
dumbest thing ever. My Moms rav4 did that. absolutely stupid
chevymitchell
Shawn
K-ville, NC
2019 JLUR (Pain Train), 2022 2500 AT4
Avi Engineer
Oh man...
Wait until you figure out you have to push the turn signal down to go left and up to go right. Lol
chevymitchell
Shawn
K-ville, NC
Avi Engineer
It's done this way because of the direction of acceleration. You don't want to push forward if accelerating is pulling you backwards. I know it's not a drag car, but it's done this way for this purpose. Same with Manual downshifting. You don't want to pull back if you and the vehicle are being thrown forward.
Anyone driving a drag car (Th350/400, for example) will swap to a reverse valve body which is essentially what this is in Manual mode, just electronic shifting.
Here's a quickie, jump to :30:
James Cole
NY
JL
LOL Jeep had it correct.
Its origin is that when you decel you have g-forces pulling you forward and when you accel is the other way around, so shift direction should be the same way.
TimmH
Timm
2018 JL Wrangler Sahara 3.6 Auto
As someone else explained it, and it helped me see it better, the menus are numbered 1-9 (at least in my '18 Sahara), and UP goes up to the next menu number (IE: 1 to 2, 2 to 3), rather than seeing it as a list.
It helps to visualize the menus in a horizontal layout rather than vertical.
James Cole
NY
JL
This.
DanN427
DanN427
Long Island, NY
If I am on page 3, then hit UP, it goes to page 2, which in my mind it is going DOWN a page. Mind boggling!!! LOL
aldo98229
Aldo
Bellingham, WA
Market Research
Sorry but that sounds like German logic —ZF is a German company.
For years, Chrysler auto shift transmissions were up to upshift and down to downshift; that was plain and simple. And didn’t require bringing in the gravitational force of the planet into it.
TimmH
Timm
You're right, I stated it the way I initially thought of it.
If you visualize it vertically.
then when you are on 3 and hit UP, you go UP to 2
sdeli
Roger
San Diego
Bolt, 4xe Rubicon
Think of the display as a window with a small view of a long piece of paper. The issue is what does the down button control. If it controls the window and moves the window “down” one gets the behavior you expect - down shows you the content “below” what you are currently seeing. If the down button controls the paper one is looking at then down moves the paper down and then you see what is above the current view. Still annoying when it is implemented contrary to how one thinks.
huntb
Ben
Michigan
18 JLUS, 22 WL 4xe
I work as an engineer for the company that produces the shifter (not ZF), and it is not a ZF spec. This was an FCA decision
