James Cole
Let us know!No I haven’t, I’m waiting for a good day to adjust the drag link a little to see if I tell the difference before I start diving deeper into it.
Are you being serious?i have a 2019 JLR. tire pressure was at 42 from dealer. first few days it felt like it was floating or drifting left to right. kind of fun.
i was advised to drop the psi to 29-32 which i did n that float feeling is gone. a part of me misses it. kept me having to stay aware. now it’s just easy driving. at times i let go of the steering wheel to test n it drives the line i drive on with zero movement.
i have stock 33s KO2. honestly it’s too quiet n feels like it’s not a jeep.
when i have friends inside i intentionally swerve the wheel to get smiles from ear to ear.
we all love JEEPS n how they wander.
you might just need new tires n drop that psi. the high psi’s is like driving on a bowling ball. too stiff n it wanders within the lane. <<<though that is something i kinda like.
Don’t adjust anything yourself if you want to keep the warranty valid. Don’t give them the right to blame it on you.No I haven’t, I’m waiting for a good day to adjust the drag link a little to see if I tell the difference before I start diving deeper into it.
I guess all that's left are the drag link and tie rods. I'm surprised it hasn't improved all that much with those new components! I just replaced the drag link and track bar with aftermarket and I really saw a huge improvement. I'm contemplating lower control arms or correction brackets, but the steering is so good I'm putting it off. Good luck!No lift Rubicon with 35" tires and after market rims
Replaced lower control arms with Teraflex adjustable arms, set caster to 5.5
Replaced track bar with Steersmarts Yeti track bar
Replaced steering (gear) box with new OEM part (not sure of the part number, I know there is a new one out now, but that wasn't out at the time)
Replaced steering dampener with Falcon 2.2
Reduced tire pressure to 34 psi
Set Toe-in to 0.20
Had dealership re-torque all other front end components (I had 2 dealers actually do this)
Still having "wondering" issue. The steering box was the largest component to making my "loose" steering better.
LCA, dampener and track bar did nothing.
Heard there might be a recall on a newer steering box so maybe that will help.
Until then, I guess I'll keep investing in front end components until it drives better
Thanks for the info, further leads me to believe it is in steering box and/or the power steering assist!No lift Rubicon with 35" tires and after market rims
Set Toe-in to 0.20
I’m not sure I have even been to full lock yet. I’ll be sure to test that before the next and 3rd time I take mine in for wander. Scheduled this week.My 2 Door Rubicon has been to the dealer 4 times now for play in the steering wheel, 1st time they did the track bar weld recall and "adjusted the steering" left me with an offset steering wheel to the right.
2nd time I went in to have them fix the wheel and they decided to replace the steering gear box at that time, part number ending in AD, not sure if that was an up date or not. The issue was still there and steering wheel was off center to the left.
3rd time I believe all they did was correct my wheel, but did tell me they were starting a star case for my jeep. Nothing ever came of that, i assume it never happened.
4th time just last week, they replace the track bar, I would guess they never even took it for a test drive after, there was absolutely no difference.
I am not really sure what to do from here.
Another question, has anyone had the issue where you do a full lock turn and the steering seem to be stuck, not going back to center without a fair amount of effort?
yes. seriously. why do you think otherwise?Are you being serious?
My 2 door is also like this. Normal I think.Another question, has anyone had the issue where you do a full lock turn and the steering seem to be stuck, not going back to center without a fair amount of effort?
You are correct, in Colorado a lemon law case starts after 3 visits for the same issue and no repair.I’m not sure I have even been to full lock yet. I’ll be sure to test that before the next and 3rd time I take mine in for wander. Scheduled this week.
It looks like you have a lemon law case to pursue if you’d like. I’m not sure what would improve if given a new Jeep. Mine is 3 weeks old and has all of the steering issues. Maybe they will build you a 2020. Or maybe pay for aftermarket parts.
You can look in your drivers side front fender well between frame and inner fender. There is a gap you can see it, at least on the Rubicon. I found it easiest to put my phone in there and take a picture of the part number.I saw someone ask but maybe it got lost in the post. How do you check the part number on your steering box? Thanks
Keep on pushing them. Don't hesitate to involve JeepCares and any other means possible. Also consider another dealership if needed, JeepCares will likely suggest getting another dealer to look at it.. They wouldnt be revising boxes, updating software if there wasnt something that needed correcting/improved!OK, so my dealer is balking at repairing or even really looking at my wandering/loose steering issue. Build date is 1/24/19 so just 2 days past the end date for the Star case with the trackbar. Not sure what to do, they say they "cannot replicate the issue" which we know is bs. I already stated I would come in and test drive with a tech. One thing they are working on and I have not heard about it is a weld issue in the drivers side door just underneath where the hardtop meets it. They are sanding, re-welding and re-painting it there. Anyone else heard about that?
Either way I think I need to invoke Jeep Cares on this (and hopefully they do care, my dealership doesn't!!)
