2mnycars
Glad to see your progress and summary.Wanted to thank all those people who took time to share their experiences and tips on trying to fix their JL steering. Here is what worked for me.
Issue: I had the 2 inches of dead play, worse in heat, with extensive wondering since the day it came off the assembly line. It was scary and exhausting to drive. Slack in steering box got worse quickly over a couple years.
JL Specs: 2018 Jeep JL Sahara, 3.6, hard top, all original suspension/tires etc. Currently has around 16k miles/26k kms. Factory order, picked up in June 2018 with around 5-7 miles on it from dealership.
What we have done to date:
The new steering box made the greatest change to the overall driving dynamic. It is still not as good as my Jeep JK was, or any IFS vehicle, but after many visits to the dealership, it is finally livable! May try the longer control arms to get it above the 90%. Good luck to you all.
- Dealership verified that suspension bolts torque to spec (I personally checked with recently calibrated torque wrench) in Fall 2018. All were to spec – no change.
- Dealership performed software update in Winter 2019 – no change.
- Dealership updated mopar steering dampener - Felt worse for some reason.
- Dealership updated mopar track bar in Fall 2019 – slightly stiffer feeling, but still wondering with dead-play and tracking all over.
- Dealership performed new alignment using revised specs that came with the new track bar – no change.
- Pulled the fuse (waited, put back in, turned wheels) to reset – felt better, but may have been subjective (wanting it to be better).
- Tightened factor box very slightly (1/8), made it feel more darty/dangerous (wheel still centered by itself) so put it back to factory setting – no improvement.
- Dealership replaced the steering rack (sorry I don’t have the part number, wasn’t on the work sheet) the end of July 2020 and adjusted the toe - Steering has improved 90% !! Far better than when I picked up new from the dealership! There is only a small ½ inch in play now, wondering is much better and steering is thankfully stiffer.
Went to school off and on in Ottawa and Nepean. Good to see your handle....Ottawa Valley almost felt like home.
