2mnycars
Thanks for your post. Interesting.The bolts at the bottom of the sway bar links shown in the photos are what I loosened. They are not LOOSE mind you. They’re not going anywhere (I put some breakable loctite in there) and there is no clanking when I go over bumps. But they are not super tight to allow the bushings to move and flex as intended.
I admit to having a Fox steering stabilizer on as well but that did not fix the problem. It’s been good for adding some weight to the steering but did nothing for the loose feeling, dead spot, and wandering.
Hopefully some other wanderers can give this a shot and see what they think. If it works for you as well as it did for me then you have a free and easy fix! Let the subjectivity test ensue...
