Loose steering feels like it has play and drifts
californiajeeping
JLUR
Bearded_Dragon
FL
2018 Mojito! Rubicon
Tried the fuse trick on my Wrangler, dead spot is still there
Robnfl
Robert
East Tennessee
2021 JLUR 3.0 Diesel - Firecracker Red
Retired USN
Was the dead spot still present when you turned the steering wheel when the fuse was out?
Yes, but the dead spot is the same as when the engine is off.
I'm pretty sure the dead spot is a mechanical issue. Especially since some owners have been able to reduce or eliminate the dead spot by making adjustments to the steering box.
californiajeeping
JLUR
What steps and in what sequence did you perform the steps? And how long did you leave it off before reinstalling the fuse? The dead spot slack could be tightened up by the electronic steering components. Maybe try again but leave the Jeep off for 5 plus minutes when the fuse is out.
Robnfl
Robert
East Tennessee
Retired USN
I followed your instructions from post 6,005 (I think). I probably waited a few minutes in between the steps, I was busy with other things at the time, trying to multitask.
Rdmitch
Ross
Elyria, Ohio
2020 JLUR, ford transit 250, 2017 Wrangler Smoky Mountain Edition
Mechanical designer /contractor and musician
i don’t know how long i left the fuse out...probably just long enough to start the car, turn the wheel and then shut it back off.
Maybe...2-3 minutes.
i don’t know why, but this seemed to help a little. maybe again just a placebo but i’m giving it another day or so to see what happens. if it helped i’m thrilled since every little home remedy moves me closer to the ultimate goal.
this weekend i’ll do the yeti track bar and the new steering stabilizer followed by the track bar brace early next month.
This should complete the process.
Bearded_Dragon
FL
Yes. Even before I attempted this you could feel the dead space with engine running or engine off.
jeepthang
Nate
Easton PA
2018 JLU Sahara
My dead spot is still there but there is definitely an improved steering feel beyond that "dead spot" zone. I have been driving around with the setting on firm on my Teraflex Falcon SS just to minimize the loose and sloppy steering feel but after this fuse deal, I'm on the medium setting and still have a nice firm and tight steering feel.
jeepthang
Nate
Easton PA
2018 JLU Sahara
I'm a little apprehensive to adjust the steering box again but think there is still some improvement there to be made. I'm at 1/8 turn currently.
jeepfan30
Bend,OR
2018 JLUR 2.0
Same here, I still have about 1/4” dead spot, but the steering feels better/tighter after pulling and reinstalling the fuse.
