James Cole
Would like to know more as wellAnyone have any info on TSB 19-002-19 for 18-20 JL and 20 JT “Shimmy In The Steering Wheel After Hitting An Irregularity On The Road Surface”? It was released 11-27-19.
That’s very interesting. I have that same stabilizer and on my Jeep, the firm setting is lighter than OEM.Wanted to provide an update on modification #2. As stated the PSC was a bit light from what I was accustom to, mostly due to running lighter stock 33's and the pump from PSC being built for heavier. I installed a Teraflex Falcon 2.2 adjustable stabilizer and went right to FIRM on the dial. Drove 40 miles home and made a very positive change. I must say that she is pretty well dialed in now..
I would say it is not hugely different, but it is more than stock. Just before I removed stock I pushed tires while on lift. The movement stock was a little less than firm on Falcon.That’s very interesting. I have that same stabilizer and on my Jeep, the firm setting is lighter than OEM.
Is the new damper worth the cost in your opinion? I am gonna ride the wave till there is a fix, FCA gives me a greenlight to fix myself or Just live with it. There isnt anything else out there i enjoy like My Jeep.I would say it is not hugely different, but it is more than stock. Just before I removed stock I pushed tires while on lift. The movement stock was a little less than firm on Falcon.
Also very interested in what this new TSB might say if anyone comes across it.Anyone have any info on TSB 19-002-19 for 18-20 JL and 20 JT “Shimmy In The Steering Wheel After Hitting An Irregularity On The Road Surface”? It was released 11-27-19.
Is this what you're referring to?Also very interested in what this new TSB might say if anyone comes across it.
Yes I guess so. Was hoping there was a bit more substance to it......Is this what you're referring to?
https://www.jlwranglerforums.com/fo...41-recall-work-done.32867/page-26#post-942582
"There's a recent update to the V41. Not only a new damper has to be installed in a correct direction, but an air from the damper has to be purged after the installation, by quickly (at least 1 revolution per second) turning steering wheel from lock to lock 5 times." - vap
I thought I’d post this for anyone who has installed the PSC kit or spent a lot of money fixing the steering.
The NCDS website is where one files for the Lemon Law claim. There is an option to request reimbursement for repairs.
I’ve got $4,500 into steering repairs and it’s still a wandering mess. I’ve filed a claim for replacement *and* reimbursement and have a hearing next month. It’ll be interesting.
Info:
https://www.ncdsusa.org/consumers/automotive-warranty-disputes/
Claim:
https://portal.ncdsusa.org/portals/claims.nsf/new_claim.xsp
Mine is wandering a lot, too. It’s very noticeable and my husband says it’s worse. I gave up on the dealers when they told me that FCA doesn’t have a solution and I was turned away from my fifth appointment.I got the most recent TSB, they told me they replaced the steering rack...tight now but wondering more than ever. Scheduled for round 7 at the dealership...I think it’s time to get out of this one.
if you moved the steering back and forth quickly that noise is normal.I've been following this thread for awhile. I have an 18 Rubicon and have had the loose steering and wander from the beginning. I changed out the track bar and drag link and that seems to have fixed the wander. I still have a couple of inches of play in the steering. what caught my attention the other morning was that it was really cold out and the steering was making a clunking noise when I turned right and left. when I was at a drive through not moving I was turning left and right and the clunking was at the end of the dead spot on either side. I don't think it was even turning enough to move the tires and it sounded like it was coming from right in front of the driver. I'm wondering if it's the steering box. I've been reluctant to ask the dealer to change it because a lot of people said it didn't make a difference, but after the other morning I might look into it.
The California lemon law is four times for the same thing not Three, and over 30 days in the shop combined. Hope it works out for youYup this is absolute madness. Completely crazy how Jeep is handling these obvious issues. Complete company line denial. Mine is currently in the shop but this will be the last time I bother talking to anyone. I'll let someone with a law degree take care of it if it's not working when they say they are done with it. 3 times in 3 diffferent shops is more than "adequate opportunity" required by CA law.
