Loose steering feels like it has play and drifts
  1. kobejo34
    kobejo34 Well-Known Member
    First Name:
    Stephen
    Vehicle(s):
    19 JLUR
    Jan 29, 2019
    Hoschton, Ga
    286
    Liked:
    140
    Garage Profiles:
    I’d settle for driving like a dump truck.
    RagTopDeluxe likes this.
  2. Tlebkcalb
    Tlebkcalb Active Member
    First Name:
    Ed
    Vehicle(s):
    19’ JL
    May 19, 2019
    WPB, FL.
    Liked:
    I totally agree, although the RPM shouldn’t fluctuate when parking. Same engine and transmission - different software logics.
    I’ve owned Wranglers since 1996 on and off thru out my life. Other than these BS, impressed how well mannered the JL is compared to every other one I had.
  3. RagTopDeluxe
    RagTopDeluxe Well-Known Member
    First Name:
    Julie
    Vehicle(s):
    2019 Punk'n JLR
    Mar 19, 2019
    Northern California
    864
    Liked:
    1,001
    Good point.
    I *love* my JL, but can’t do anything with it because we’re not comfortable driving it anywhere beyond work because the steering.
  4. Alpha Delta
    Alpha Delta Well-Known Member
    Vehicle(s):
    Jeep Wrangler JLU
    Feb 24, 2019
    Maine
    141
    Liked:
    247
    You already invested in some nice SS components, have you considered installing a full PSC steering overhaul, especially if you love your JL? I know the price is steep. Also, have you tried the preload adjustment on the box? I’ve read some successful stories but most do caution against it. I’m becoming very skeptical that they’re adjusted to spec at the factory. I’m wondering that since they’re aluminum now, they’re building in extra play so there’s no chance for significant binding and total steering failure to cover themselves.
    We’ll be taking our JL for service to start with the basics (torquing all components to spec and alignment) and going from there. My wife struggles driving it and It’s getting annoying driving it on the highways. We will eventually be doing a CO/UT/AZ road drip from Maine to finally enjoy some legendary trails but there’s no way I’d go the way it drives now. We love our Jeep but the steering sucks with the constant wondering and the steering wheel play. It becomes especially pronounced after 60 mph.
  5. Rdmitch
    Rdmitch Well-Known Member
    First Name:
    Ross
    Vehicle(s):
    2020 JLUR, ford transit 250, Chevy Equinox
    Jan 13, 2019
    Elyria, Ohio
    414
    Liked:
    337
    Occupation:
    Mechanical designer /contractor and musician
    Maybe you will have better luck, but the AE steering box was no better than the AD one.
    Sure wish these were adjustable so they could tighten up the response.
  6. James Cole
    James Cole Well-Known Member
    Vehicle(s):
    JL
    Jun 29, 2019
    NY
    136
    Liked:
    34
    They are adjustable... Its just not very clear to me why FCA doesnt want us to touch the adjustment.
  7. Rdmitch
    First Name:
    Ross
    Vehicle(s):
    Jan 13, 2019
    Elyria, Ohio
    414
    Liked:
    337
    Occupation:
    That’s funny.....read my avatar
  8. RagTopDeluxe
    First Name:
    Julie
    Vehicle(s):
    2019 Punk'n JLR
    Mar 19, 2019
    Northern California
    864
    Liked:
    1,001
    “Special Walmart shopping cart edition” :LOL::LOL::LOL::LOL::LOL::LOL::LOL::LOL::LOL::CWL::CWL::CWL::CWL:
  9. RagTopDeluxe
    First Name:
    Julie
    Vehicle(s):
    2019 Punk'n JLR
    Mar 19, 2019
    Northern California
    864
    Liked:
    1,001
    That’s a thought — a very expensive thought, tho. I have also considered swapping out the drag link and tie rod with Steer Smarts. However, the dealer has mentioned taking mine back to stock to see how it does. Grrrrrr
    Honestly, for the first time, I’m thinking about lemon law/buy back.
    I drove it on the freeway this morning and was pondering the difference between it and the sport loaner I recently drove. That had a bit of play (maybe around one inch), but it still drove much better than mine. In my JL, it seems that in addition to the play, there doesn’t seem to be enough connection between the steering wheel and what the Jeep should do. I don’t know if that makes sense, but it’s not just play.
    So what is the problem? I was sure it was the steering box, and it must certainly be part of it, but what else is going on?
  10. Rdmitch
    First Name:
    Ross
    Vehicle(s):
    Jan 13, 2019
    Elyria, Ohio
    414
    Liked:
    337
    Occupation:
    #4390 Sep 29, 2019
    Just food for thought....and I’m no car mechanic. Hell I can hardly follow the manual.
    Now, if the steering is loose, and you can move the steering wheel it a inch or so either way with no direct wheel reaction, wouldn’t it also work in the opposite way. Meaning the wheels can follow there own mind without you, as a driver feeling any change in the wheel?
    So you’re holding the steering wheel straight but the tires an move either way with out you having any input.
    If the steering was tight, it couldn’t wander. So what s the device/part that controls the tightness of the steering wheel ?
    I don’t see that as being a damper, tie rod or alignment items. I only see the direct link from the steering wheel to the mechanism as the gear box. Why can’t a dealer try to adjust a hair at a time and document the results?
    So..if you went to a dealer lot, started a wrangler and the wheel is nice and tight, wouldn’t it be likely this was not a wanderer?
  11. M0ondogy
    M0ondogy Well-Known Member
    Vehicle(s):
    None
    Jun 4, 2019
    MD
    100
    Liked:
    75
    Add me to this problem.
    Tires at 36 psi across the board.
    Wife drove for the first time today and got in a tank slapper. I had the grab the wheel, hold it steady, and instruct her not to touch any peddle.
    This should not be a thing at 55 mph.
    I'm going to schedule an appointment with my dealer in the morning.
    I'm going to read the thread in a couple of minutes here, but won't be done for a while. It's a big thread.
    What's the solutions up to date from FCA and are they working?
  12. Rdmitch
    First Name:
    Ross
    Vehicle(s):
    Jan 13, 2019
    Elyria, Ohio
    414
    Liked:
    337
    Occupation:
    What’s a tank slapped ? Is that the same as a wobble
  13. M0ondogy
    Vehicle(s):
    None
    Jun 4, 2019
    MD
    100
    Liked:
    75
    Kinda. Tank slap is a motorcycle term, but it's the best word for this situation.
    It's when the Jeep starts swaying side to side.
    Inexperienced drivers try to correct and end up flipped.
    Any faster than 55 it would have flipped.
  14. Rdmitch
    First Name:
    Ross
    Vehicle(s):
    Jan 13, 2019
    Elyria, Ohio
    414
    Liked:
    337
    Occupation:
    Learn something new every day here
    Good luck with your dealer and enjoy reading the last bizzillion posts
  15. HoundDude
    HoundDude Well-Known Member
    Vehicle(s):
    2019 Wrangler JL Sahara
    Sep 19, 2018
    New Jersey (i know, i know, i'm stuck here)
    493
    Liked:
    306
    this is a new complaint I haven't heard before, I'm not sure you will find any help in this thread.
    keep in mind that once you turn the wheel though the dead spot, the power steering may kick in abruptly. so if your wife was turning the wheel without getting a response (while in the dead zone), she may have overreacted and turned it too much (and power steering kicks in). and back and forth. driver induced oscillation. DIO.
    welcome to the JL. file your complaint here:
    https://www-odi.nhtsa.dot.gov/VehicleComplaint/
    df007 likes this.
Loading...
Share This Page
