Hi stange8017,So I brought my newly purchased (literally 3 days ago) JLU in to the dealer service department after I told them, "My wife is afraid to drive it because you have to make perpetual micro-adjustments when driving at high speeds."
The first service tech I talked to thought I didn't know what I was talking about. So I called back later and talked to someone else. The second service tech really wanted to understand the issue and so I asked him to watch the Jeep Informant video, then I brought the Jeep in and demo'd the issue.
Without even taking the car out of park they immediately recognized something wasn't right and gave me a loaner while they get to work on it.
We'll see how it goes. I'll keep everyone posted.
My hope here is that after a slight castor adjustment and a tightening of the pinion nut I'll walk away a happy customer with very little inconvenience.
Thank God no one has gotten hurt while waiting..how long can that go on?And so we keep waiting, and waiting, and waiting, and.................................
FCA ENGINEER VISIT UPDATE!!!!
This morning I met with 2 engineers who drove from Michigan to my dealer to go over my JL.
We went for a test drive and I showed them my remaining steering issue / concern.
The good and the bad. The bad is with the tire pressure corrected, Ball Joints now tight, TSB and 1/4 on the steering, It actually does not drive that bad at all now. I was also told the way the new steering box was designed, that specific steering box, to remove looseness in the steering, Doing it by the adjustment on the top of the box is not recommended and hence the nearly impossible lock tight. The steering box if it needed to be adjusted needs to be done as a whole and with proper tools and measuring devices. He showed me the steering box that I was suppose to get replaced a few weeks ago and went over how its designed. I get it and I truly believe this. If it was this simple the 1/8 for 1/4 would have fixed everything.
They checked the alignment and it was dead on and interesting my caster was like 5.1 and 5.4 which he thought was perfect.
This engineer was really cool and extremely knowledgeable. I am beyond impressed. Heck I think he had every tolerance of the JL memorized.
They drove down from MI in a JL. He also looked at 2 other JL's on the lot to get more data and details with the build date from those Jeeps.
He stated each part on the JL has a serial number. By looking up the data on these components, specifically the steering box, they can get the build date of the part and I am guessing recorded tolerance from the supplier.
He did go on to explain the JL was a complete redesign of the JK and even the steering was designed to require less effort. But they have received many complaints about the JL steering. What they have noted is, its not just been one item. Some complaints have been fixed with the TSB. Some with the tire pressure and some have no issues at all. Some new to the JL having owned prior vehicles with electric steering and so fourth finding the steering in the JL unsatisfactory.
But they did assure me they are working to compile all of the data on each vehicle they look at to come up with a solution.
For my concern, They will have a plan by next week for my service advisor.
Very interesting read, every JL should come with a torque wrench, 22mm scocket and 4 cotterpins so that as being the owner of a JL costing over $50k they can go and tighten their own ball joints. And itās interesting that no one else could apply LockTite to a nut on the steering box adjustment nut other then the supplier of the steering box. Did they say how they would correct the caster if it was not what they felt happy with?Wow that sounds like a little too late. I thought they already knew the solution and everything would be corrected on the 2019.
Hello BeauSabreur,I took my 2-door 2018 JL Rubicon into the dealership today. I asked them to flash TSB 08-092-18. They told me that this TSB did not apply to my vehicle because it was built in June 2018. In fact this TSB could not be (force) flashed to my vehicle. Only vehicles produced before May 2018 could receive this TSB. They checked their database and didnāt see any service bulletin addressing steering issues for JLs built post May 2018. So (1) Iāll continue to watch this Forum for future fixes. (2) I will contact FCA and report my problem. And, (3) Iāll check with my dealership again at my next routine service appointment.
Just filed a complaint with NHTSB. Maybe if enough of us do it Chrysler might speed up a resolution. I just returned from a dealer that kept my JLU for 3 days. When I picked it up it said nothing was done and that they had contacted Chrysler/Jeep and were told that Jeep intentionally built in the steering wheel play??? Maybe like Boeing would leave off a tire on a 747! I am going to open a STAR case with a dealer. Per the Jeep Care center, that will require Jeep to send a factory technician to evaluate the issue.File a complaint with NHTSA. Couldnāt hurt.
Yep . Can you imagine an airplane with too much rudder play ?were told that Jeep intentionally built in the steering wheel play??? Maybe like Boeing would leave off a tire on a 747!
There are currently 126 steering complaints on NHTSA. How many does it take before Jeep recognizes there might be a problem? āToledo, we have a problemā.Just filed a complaint with NHTSB. Maybe if enough of us do it Chrysler might speed up a resolution. I just returned from a dealer that kept my JLU for 3 days. When I picked it up it said nothing was done and that they had contacted Chrysler/Jeep and were told that Jeep intentionally built in the steering wheel play??? Maybe like Boeing would leave off a tire on a 747! I am going to open a STAR case with a dealer. Per the Jeep Care center, that will require Jeep to send a factory technician to evaluate the issue.
