Looking for this wheel style with Tires mounted
Howardlv22
Howard
Arizona
2021 JLU EcoDiesel
I think you meant "ARCUS".....not oculas. Just installed mine this weekend. Pain in the ass to install, especially with no help....but I love the look of it.
Yes sir 😂
blnewt
New Mexico
Just ask @cosine he knows!
CAN black rhino wheels be custom offset made..
Still having trouble find the wheel that will not stick out of well.
How will this one work?..offset is -18
https://www.cjponyparts.com/black-r...2018-2021-gladiator-2020-2021/p/795ARY512G-B/
You have 2 choices in a 17, a 17x8.5 +30 and a 17x9.5 -18, very dramatic difference in the fit between those two.
Just for comparison here's a couple fitments, the first one is your stock setup (285/70/17 tire on a 7.5 +44) and the 17x8 +30 on the stock tire, the second is the stock setup vs. the 17x9.5 -18. and the third is the +30 wheel vs. the -18 offset. Thje +30 offset is closest to an AEV wheel set that's specifically designed for the Rubicon w/ a +25 offset.
The difference in link 3 shows about 2" more that the -18 will poke out from the +30 set.
https://www.wheel-size.com/calc/?wh...70-17X8ET30&fcl=2in&wcl=1.25in&scl=2in&sr=0in
https://www.wheel-size.com/calc/?wh...17X9.5ET-18&fcl=2in&wcl=1.25in&scl=2in&sr=0in
Not sure if you like those Warn wheels I posted, but at zero offset, that's a perfect compromise between the two Armory wheels FWIW.
22Mag
Craig
20 JL Willy's
Here are the black rhino abrams in a -18 offset with 315x70r17 ridge grapplers. The rims are green to match the sarge color. They do stick out a bit but not overly so, they ride very nice.
msdesignltd
msdesignltd
michael
Long Island
2020 wrangler Recon unlimited
Ah, The minus 18 appears to be very close..do you have a pic of the tire stick out from behind the car and in line with the side of car...Thank You!
blnewt
New Mexico
Jeep Wrangler JL Looking for this wheel style with Tires mounted PXL_20210302_165755714
nice look! the angle of that photo looks like you scratched the hell out of it though :crying:
22Mag
Craig
20 JL Willy's
No scratches yet, that's the reflection from the painted lines in Cabela's parking lot.
22Mag
Craig
20 JL Willy's
Is The willys front fender narrower than the rubicon...your turn lens appears narrower?
I don't know, i've never noticed that. possible the rubi has larger fenders.
