You can take pictures of the ones you need and email or chat with them. They are pretty good at coming up with solutions or can point you in the right direction. I run the parts department at a collision shop and they are a life saver for these things. Pigtails and connectors are super hard to come by as most OEMs dont want you messing around with it.Unfortunately nothing there works for me.
That was my first thought but the yard around here sucks. Pretty dry here in Wisconsin for that. Maybe if I go over to MilwaukeeI would check the local junk yard to see if you can find the other side. LKQ is another place to check as I have not seen a bunch of JL's at the yards yet. I keep looking though! Around here we have several junk yards but there are guys there that work it full time taking all the good stuff off and selling it on eBay.
I got mine from mouser.com. The only one they don't have is the gray one, which goes to the rear bumper sensors. I have a gray one I'll sell you, $5 shipped to you. I bought it from a seller on ebay and minimum order is qty 5. The front one is blue, and the power/can connection connector is black. The pins for all 3 are available on mouser. Total costs for all connectors and their pins is around $20. The connectors for the sensors is 84 cents a piece from aliexpress and they give you the pins also. I ordered 20 and they will be arriving in a week. I don't need 20, but I can sell you 10 if your interested. so $10 will cover those and the gray connector. I don't have enough pins to sell you for the gray connector, but the pins for all 3 connectors to the module are identical. If you have alldata, just query the connector view, and it will give you the part number for all 3 and the pins. I just used .5mm wire which is pretty much all the wiring except the power, and there I used .75mm.Looking to make my own rear park sense cables. Just need the Pigtails of the left and center. Can anyone direct me to these. I’ll also need a star connector. But I believe I can find that one easily
thanks got it done a while ago.I got mine from mouser.com. The only one they don't have is the gray one, which goes to the rear bumper sensors. I have a gray one I'll sell you, $5 shipped to you. I bought it from a seller on ebay and minimum order is qty 5. The front one is blue, and the power/can connection connector is black. The pins for all 3 are available on mouser. Total costs for all connectors is around $20. The connectors for the sensors is 84 cents a piece from aliexpress and they give you the pins also. I ordered 20 and they will be arriving in a week. I don't need 20, but I can sell you 10 if your interested. so $10 will cover those and the gray connector. I don't have enough pins to sell you for the gray connector, but the pins for all 3 connectors to the module are identical. If you have alldata, just query the connector view, and it will give you the part number for all 3 and the pins. I just used .5mm wire which is pretty much all the wiring except the power, and there I used .75mm.
