Looking for new wheels that don't stick out 3"+
Cookiedawg
Indiana
2018 Jeep Wrangler JL Sahara
Read the above part you quoted and it tells ya what kit I installed ;-) it's not the Mopar lift.
Here are a couple side shots.
Nice!
lightsout
PNW
I just installed the Rancho 3.5" lift on my Sahara, Most of the lift manufactures recommend a backspace of 4.5 4.75. with 12.5" wide tires. I originally had XD wheels with a 5.71 backspace and they were too close to rubbing and likley would have at flex. I ended up swapping out for Fuel wheels at 4.71 backspace, however there is no way around sticking out 2"-3"
Here is the 4.75 Backspace In fact today I just installed XL wide Mud Flaps so the extra width not a problem for me
Here is the old 5.71 Backspace
Andras
Andras
Land Rover LR4, Jeep Wrangler JL
I had the same issue with the wide axle.
For my Rubicon JLU originally got black rhino mint 18" wheels (-18mm offset). Wheels looks very high quality - but I did not like the skateboard look either. It looks silly sticking out that much. Later I got ultra crusher wheels (+12mm offset) - which are much better.
drock317
drock317
Derek
Indianapolis, IN
2018 JLUS - Ocean Blue
It's a matter of opinion. I did not want the entire outer lug of the tires sticking out like your pictures. I like the second picture look better for my Jeep than your first one. And if you had 5.71 backspacing and a 9" wheel(+18) that would only move you 6.9mm from your suspension but with my 8.5" and 5.46 backspacing (+18) it moves it 13mm away from suspension but doesn't stick out as far and flexes without rubbing so far. I can go full lock just fine too.
Also the suspension companies that had those backspacing suggestions havent done the math or trial and errors on different wheels. I called rancho and others to talk to them about it and they told me they just used the JK specs cause they know they worked.
AEV is a company who has the entire Jeep converted to AutoCAD drawings and are doing all the math and building wheels to look OEM and still be functional and plan to do a +25mm offset on an 8.5" (5.73 backspacing) wide wheel and show that they tuck without rubbing.
Mbz300sdl
South Carolina
2018 Jeep Wrangler JL Sport, 2014 Mercedes GLK350, 2008 Chevrolet Tahoe
Got them on a couple weeks ago :) 295/70/17 on 17x8.5 +10 wheels
Those look great I was looking at those same wheels and tires. Other than the 285s instead of the 295s I see you have had them about 5 months since yours post how are you liking them? Also have you had any issues? Thanks
timn1984
Tim
Louisville, KY
Jeep Wrangler Unlimited 2018 JL Sahara,Dodge Journey 2012, Toyota Camry 2015
Yes
What kind of rims are those? They look nice.....
blnewt
New Mexico
Just ask @cosine he knows!
Still very happy w/ the combination, wearing real well and settled on 30 psi for running pressure and a bit more comfort (since these are E-rated). I would buy both again without hesitation. If you get 285s you'll have just a bit more room around that plastic fender section (between the actual bumper and the fender) as this was the only place where there was just a bit of contact at full lock but not enough to be a concern TBH. 285s might also be available in a D or even a C rated which would make them a bit more compliant on a lighter Wrangler, although I've found the ride quality on the E-rated to be just fine :)
Wheels seem to be nice quality w/ a good finish and balanced without any issues, have nice design features too IMO, get lots of positive comments on them :)
JIMBOX
JAMES
FERNLEY NV
RETIRED
Yeah, I would never put "C" rated tires on a WRANGLER used on the street and also they are very subject to sidewall damage off-road !
I've been using "E" rated BFG/HANKOOK on all my Jeeps/Toyotas/Xterras and NO PROBLEMO !
W.E.
JIMBO
JL2021guy
JL2021guy
Daly City
2021 Jeep Wrangler rubicon 3.6
Jeep fun
I too did not want tires that stick out too far, for fear of passing inspection. Best wheel option I could find that had both positive offset (+10) and was hubcentric, was Quadratecā€™s 41ā€™ wheel.
Iā€™m really happy with the fitment on 315/70R17 KO2ā€™s with the RC 2.5ā€ lift. If your willing to do a 17, I canā€™t recommend enough, especially with the C rated rubber.
Side profile pic is before lift FYI
What is the actual weight of the 41 rim. Not shipping weight please and any rubbing at full flex lock to lock ?
Thanks šŸ˜Š
