Looking for better & safer lug nuts
Fire Burns
Fire
CA
Now got me curious enough to check the seats on my Hostile wheels and will plan my lug nuts accordingly!
blnewt
blnewt
New Mexico
Just ask @cosine he knows!
Got the 22mm socket today, and BINGO, it fits well inside my wheel lug bores w/ a couple mm to spare, so the first part of the puzzle fits, and the lug nuts should be exactly what I was wanting, should be here Friday :)
gpurp
North Texas
19' JL Sport 2dr
Excellent! Post pics when you get them installed.
blnewt
blnewt
New Mexico
Ok, first off, the OD of the 22mm 6pt socket is right at 30mm, so if your aftermarket wheel lug bores are in the 31mm or larger OD you're good to go! If you can find a 12pt 22mm socket that may allow you a bit more room but YMMV, and 12pts tend to round off lug nuts so buyer beware there,
The actual diameter of the lug nut seat is 26.8mm (so quite a bit larger than the largest McGard splines, and MUCH larger than the standard 22mm OD on the standard spline nuts). Also these would be great for all of you that have factory wheels but want them in a black finish :)
Pics of wimpy 22mm splines~
Pics of new 26.8mm hex lug nuts~
22mm closeup~
And the big boys~
Not sure about you but I KNOW what I want holding the most important Jeep parts together :)
Again parts are~
https://www.amazon.com/gp/product/B000FOIB8Y
gpurp
North Texas
19' JL Sport 2dr
Too bad my lug bores are only 28.5mm. I'd have to find a super thin wall 22mm socket to fit that. Doubt there's such an animal and so far I haven't found one. Another option is use a 19mm bulge acorn lug nut. Grey Pneumatic provides the dimensions of all their sockets. A regular 19mm deep socket has a 28mm OD. That would fit my wheels. Or I could go with their extra thin wall 19mm socket that has a 26mm OD.
https://www.gpsocket.com/products/category.phtml/individuals_and_attachments/1_2/
blnewt
blnewt
New Mexico
I doubt there's a 22mm socket that thin, the 12pt craftsman 22mm might be a bit smaller than 30mm but not at all sure how much :(
Those Mcgard spline nuts have a bit more coverage and have a 24.1mm socket size, but they are pricey :( Might be your best option though.
jdubya421
Jakob
Greensboro, NC
2020 Rubicon 2-Door MT V6
Thank you for this thread. I have been searching for some regular 6 point lugs that fit into my wheel bores. I personally do not want to run any kind of locking mechanism because that is one more thing to forget or break on the trail and strand you. I will have to do some measuring on my wheels and see if the same thing can work for me.
blnewt
blnewt
New Mexico
They make 22mm thin wall sockets for tight clearances for exactly this reason.
https://www.amazon.com/ARES-70023-1...s=22mm+thin+wall+socket&qid=1587779628&sr=8-2
Yeah, I looked at those but that outer sleeve makes the clearance too tight for my application. It comes out to 33mm, the socket that I found is 3mm smaller at 30 mm.
This is taken directly from that Amazon listing
DIMENSIONS: The outside diameter of this non-marring lug nut socket is 1.3 inches. Please note that some wheels have very confined lug wells and the outer nylon sleeve may be prohibitive in accessing the lug.
gpurp
North Texas
19' JL Sport 2dr
Wolfpac81
Sheldon
DE
2020 JLR M/T (ordered)
If you slide the plastic cover off, it it a really thin wall socket. I've used it without the cover to great effect.
blnewt
blnewt
New Mexico
Sheldon, it you get some time would you mind measuring the OD w/ that cover off, would be a nice to know as that would be a good choice for sure!
Wolfpac81
Sheldon
DE
I'll check it tomorrow.
Wolfpac81
Sheldon
DE
I measured the 22mm wheel nut socket with the plastic cover removed. It is 1in and 5/32 (just a hair under 1in 3/16) it was the exact same diameter as my 12 point deep 22mm Craftsman socket if that helps. So if a 12 point 22mm fits but want a 6 point option it would fit the bill.
