Looking for a winch mounting plate for a stock bumper on a Sahara
JSFoster75
Bluff City, TN
HiJinx69
Richmond, VA
2018 Wrangler Sahara Unlimited JL, 2014 Mazda 6, 2010 Honda Odyssey, Yamaha FZ-09
I have a 2018 Wrangler JLU Sahara with a factory plastic bumper, looking for a winch mount that will work with the badlands series 9000 pound winch. If you have any information that will help with this, please let me know. Links are greatly appreciated...
https://www.harborfreight.com/zxr-9000-lbs-trucksuv-winch-63769.html
I don't think it exists for plastic bumpers. You'll have to upgrade to a steel bumper. Most come with a built in winch plate or you'll have to buy it separately.
JSFoster75
JSFoster75
Bluff City, TN
any suggestions for an inexpensive one that I can use that will utilize my factory fog lights?
Redneck_Jedi
Currently Roaming
2019 Jeep Wrangler Sport S 2 Dr.
Most Winches have a pretty standard mounting layout. Here is a mounting plate that should work with the Sahara plasfic bumper.
https://www.rockhard4x4.com/product_p/rh-90205.htm
You could always email or call Rockhard 4x4 to confirm.
Also, Harbor Freight just released a new 12,000lb, IP68 rated winch for $599 that has a Synthetic line and wireless controller:
JSFoster75
JSFoster75
Bluff City, TN
thanks for the link, I knew I had seen one somewhere but I just couldn’t find it.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Dang that blocked half of your radiator intake...
Rudolph Hart
Cheshire UK
2018 JLUR GME Mojito!
Semi retired
It’s a compromise isn’t it....because you can’t sensibly mount the fairlead to a plastic bumper they’ve had to lift the winch above it. Also I’d prefer the winch to be mounted more in line with the front end of the frame...like this
Redneck_Jedi
Currently Roaming
Above bumper winch mounting can certainly block off part of the airflow to the radiator. However, they do often provide the benefit of keeping the winch above mud and water, and also making it easier to see the line spool. Not to mention the weight savings of not needing an aftermarket bumper. Many well known Overlanders around the world use this type of winch mounting location without issue, such as Venture4wd and 4xOverland. I suppose if cooling ever became an issue, a grill from a JT could be always used for additional airflow. I think I'd prefer to go with an aftermarket aluminum, light weight bumper, that mounts the winch between the frame rails and provides a somewhat lower center of gravity.
Redneck_Jedi
Currently Roaming
GoHack
Gordon (N7QEI)
SoCA
2018 Sting-Gray JLU Sport, DoM 7/18 (Wed)
Mech Engr
