Long Rang America Aux Fuel Tank installation
Redbaron73
Ronnie
2020 sport s unlimited;2020 Rubicon Unlimited
This is a picture heavy thread showing MY*JLUR LRA tank install.
#Pic 1 - View of the Fill neck Y valve. This is a supplied T that connects inline with the OEM fill line.
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_191141
Pic #2 - DIfferent Angle of fill neck
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_191127
Pic #3 - This is taken from the rear, looking up. You can see the fuel transfer pump located high. Directly behind the fuel pump is the TPMS sensor. I shared the hardware for mounting both.
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_191100
Pic #4 - view from below showing how the OEM tank looks vs the LRA tank
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_191043
Pic #5 - Slightly Different Angle
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_191038
Pic #6 - View from Drivers side. Heat shield was added to exhaust to protect the LRA tank.
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_190735
Pic #7 - Different Angle
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_190740
Pic #8 - Up close look at the mount for LRA tank at the front.
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_190750
Pic #9 - Side View - Drivers side. Notice the low point drain
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_190757
Pic #10 - Center view showing clearance of drive shaft
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_190811
Pic #11 - Closeup of mount
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_190831
Pic #12 - Another Side view
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_190931
Pic #13 - View from rear
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_190955
Pic #14 - View from Rear - Better Angle
Jeep Wrangler JL Long Rang America Aux Fuel Tank installation 20210401_191004
SH556JL
Steven
Florida/Georgia
21 JLR M6 RIP, 23 JLR M6
I assume this is for a JLU? By chance, is their one for a 2 door?
Redbaron73
Redbaron73
Ronnie
No. And not for the etorque either. Only the Diesel, 2.0T, and 3.6 without etorque, all JLU
Mtpockets
MT
Massachusetts
2021 Rubicon 4-Door
Looks good. Pease of mind knowing you have extra fuel on board.👍
UTES
Hunter
Salt Lake City
2020 Diesel Sahara, 2018 AMG GT, 2019 MB GLC
Retired LEO
You did what appears to be an outstanding install of a larger fuel tank.
What is the capacity difference between stock and the LRA tank?
Thanks,
Hunter
Redbaron73
Redbaron73
Ronnie
The diesel is available from the longranger. This is distributed by ARB Australia.
http://thelongranger.com.au/jeep/wrangler/jl/diesel/4-door
As for the 2.0T, the same 3.6 tank will fit, but you need to modify the exhaust. I plan on doing this install on my Non-Etorque 2.0. I will document the modifications required.
Quick
CT, USA
Cool - looks like those are local pre-order only, though. Hopefully they fully release it and make it available here - though I fear EPA restrictions will make that nearly impossible.
Redbaron73
Redbaron73
Ronnie
They are available to order to USA. I originally was going to order their kit, but found the American company that is importing and dealt with them instead.
Pricing is identical including freight. Lead times are different.
The 2 companies are Long Range Automotive and The Longranger. Both are out of Australia, where the tanks are made. The designs are virtually identical, and I have heard several variants of the explanation for the difference between the two. The owners are closely related, but they operate independently and as competitors.
