LoD Destroyer Series Sliding Roof Rack
m3lover1
Ricky
Bay Area, CA
2019 Sting Gray JLUR, 2007 Yamaha R6
Are you planning on releasing the support bars pictured in one of the photos you have with the tent supported with the slider extended?
If so, how soon? And will it support the 800lbs Static as well?
Highly curious about this as well!
LaneSprings
Daniel
Colorado Springs, Colorado
2018 Wrangler Sport S (JL)
Auto Insurance Agent
Hey LoD, question for you. I’m really into your products. Got your bumpers on already and looking at more things from you as well. The question is... is this or will you guys ever have some sort of rack that will for the 2 door? Would be nice to be able to continue building the LoD JL 2 door...
Gregorysnelson
Greg
Greenville, NC
Jeep Wrangler sport+ unlimited
Axia alloys
LED light Bar Mount End Mount 8 mm 5/16″ end mounts
Part# MODLED8
that’s how I got my pro 6 8 light bar on.
worked perfectly.
For the light bar, I assume that you did not use the KC HiLites mounting bar since the LOD rack uses the a-pillar for the rack mounting. I see that you said you used the axia alloys clamp but how did they mount since it looks like the light bars attach at the end caps rather than having a bar that runs along the back. thanks in advance!
Tug
Kyle
CT
2022 JL Rubicon
Ordered. Will post pictures!
RSenese
2019 JLUR
post # 137
m3lover1
Ricky
Bay Area, CA
Installed the rack today, but not finished yet. Still have to work on the sliding part as it's not smooth. That and couple more steps and I should be good to go. Only couple hiccups. LOD shipped me the driver side ladder instead of the passenger side which I ordered. Other was trimming and fitting the taillight. Took a long time to trim, even using the cutout they provided. There's a gap on both driver and passenger side on the inside of the light housing. And due to really hard time fitting it back in, theres quite a bit of gap on the topside of the housing where it was trimmed, as we had to continue to trim more and more to try to fit the light in the housing. Other than that the process was pretty smooth.
Big thanks to @RSenese for help along the way even though he's on the opposite side of the country. Major props.
Here are some progress pictures. Didn't take much and took it quickly...
Canuck714
Zach
2013 JKU Rubicon, 2014 Roush Raptor, 2020 JLU Willy's
Looks great. How noisy is it going down the road. I can only imagine that the sliding part would rattle back and forth in the tracks.
Please let me know what you notice.
m3lover1
Ricky
Bay Area, CA
Definitely no rattle from the tracks. It's latched on front driver and rear driver side as mine slides out on passenger side, and also has extra safety bolt on front and rear passenger side. The basket doesn't move at all once it's latched. I am dealing with flapping of my soft top at highway speeds, that is causing a bit of noise. Trying to resolve that. Note I have the premium soft top and I surmise the softer material might play a factor in the flapping.
Seattle
2019 Mojito JL Wrangler Unlimited
Anyone or that has installed this LOD rack or LODoffroad, can we get a pic of what the rear lights look like with the rack installed? I would like to know what it looks like when it is all put back together.
Do you need to worry about water or anything when you cut the light housing for brackets to fit?
Thanks
m3lover1
Ricky
Bay Area, CA
Thanks
I'll post some in a bit. I did cut off a bit more than I had needed as I had issues putting the light back on so kept trimming and trimming. In terms of water, yea im a bit concerned with how I cut mine, but even then I'm not sure how watertight it was to begin with pre cutting anyways
Tug
Kyle
CT
2022 JL Rubicon
I should be doing the install soon as well and would love pictures if you have time to post them. I'm hoping to be able to mitigate the water entry issue somehow. I know that it should just travel out the pre existing holes, but I'd like to keep it to a minimum regardless.
Seattle
Thanks! That would be great. I would like to know what it looks like when all is done.
m3lover1
Ricky
Bay Area, CA
Driver side:
Pass side:
Again not the best cutting on my part, and probably will look at epoxying some plastic bits to it. Hope it helps.
Tri-City Jeep
